03-09-2010, 03:22 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1254711 Status: Offline Thanks Meter: 0 | N97 Mass Memory When I connect my USB device in n97 is giving this error on the device: "Memory card missing. The USB connection may not work as expected.". I've tried everything, I hard reset (shift, backspace, space), reinstalled the firmware, took battery, chip, expected some time later I called again and continue with the problem .. I can not format the device by windows says the disk is write protected .. I can not access the files from mass memory, read .. However I can not delete or create files .. I have tried: Hard reset, format the file manager (not enjoy the option to format), reinstall the firmware. . Sorry my bad english |
01-07-2011, 23:32 | #4 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: Bulgaria,Veliko Tarnovo
Member: 131788 Status: Offline Thanks Meter: 69 | I already have this problem few times and sloved Quote:
Rehot with Hot-Air Rework Station Samsung NAND-Flash chip and will be ok. If this will not help you, you must change Nand-Flash, maby chip is defected. And Final if,wil not slove - Rehot CPU. Br. | |
N97 Mass Memory In Use Problem | SworDTr | Nokia Hardware & Hardware Repair | 22 | 12-03-2013 16:41 |
n97 mass memory problem | tajammal_ranjha | Nokia Hardware & Hardware Repair | 15 | 12-02-2012 12:01 |
Need N97 and N86 mass memory content | Crazy_ratata | Nokia Base Band 5 ( BB-5 ) | 0 | 12-02-2009 16:25 |
N97 mass storage problem | meisam | Nokia Base Band 5 ( BB-5 ) | 5 | 09-17-2009 10:46 |
