03-28-2010, 07:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: B.DESH (narayangonj) Age: 39
Member: 648428 Status: Offline Thanks Meter: 846 | nokia 5530 When Make calls the mobile power off |
The Following 2 Users Say Thank You to md.nazmul For This Useful Post: |
03-28-2010, 07:53 | #5 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | first check with software if there is any damage in super dongle if software is ok then change ear piece if not ok then it will be pfo |
03-28-2010, 08:13 | #6 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 746552 Status: Offline Sonork: 100.1594844 Thanks Meter: 110 | for nokia 5530 I faced same problem..after many work my phone had complited, if phone are make restart in both time incoming or outgoing. for solve you can try by software. if faced this problem when making call you can try to solve this problem by hardware. you should open the phone and cheque by different way,,,, such as,,,mother board *******, short, lcd attaching etc. by this way I think you will be able to solve your problem. |
03-28-2010, 08:27 | #7 (permalink) |
Member: 746552 Status: Offline Sonork: 100.1594844 Thanks Meter: 110 | try this way ........ I think your problem will be solved for nokia 5530 I faced same problem..after many work my phone had complited, if phone are make restart in both time incoming or outgoing. for solve you can try by software. if faced this problem when making call you can try to solve this problem by hardware. you should open the phone and cheque by different way,,,, such as,,,mother board ******** , short, lcd attaching etc. by this way I think you will be able to solve your problem. |
The Following User Says Thank You to vertex777 For This Useful Post: |
03-28-2010, 09:06 | #9 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | .................................... here solution sir |
The Following 12 Users Say Thank You to yarra For This Useful Post: |
nokia 5530 auto off when making call | vertex777 | Nokia Base Band 5 ( BB-5 ) | 13 | 03-01-2012 11:05 |
5530 rm-504 Off when making Calls,Flash Ok --Same. | blaiseid | Nokia Base Band 5 ( BB-5 ) | 43 | 07-10-2010 00:19 |
5530 Make calls the mobile power off 100% tested solution | md.nazmul | Nokia Base Band 5 ( BB-5 ) | 11 | 05-22-2010 09:01 |
motorolla auto power off when making call | HITGSM2001 | Motorola Hardware Repair | 4 | 06-17-2002 05:43 |
