12-08-2009, 18:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | 5530 rm-504 Off when making Calls,Flash Ok --Same. I ve a 5530 rm-504 Off when making Calls,Flash Ok ,but same problem.Checked the pcb everything smart.Tried to heat litely the board but still same problem,Someone faced this before??? Thanks |
12-15-2009, 11:24 | #3 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Unknown location
Member: 1092212 Status: Offline Thanks Meter: 111 | here also same problem i wnt flash but can't ufs log 1ST BOOT : C0,07 [Rm-504] [2.0.9.0] RAPx ID : 000000010000022600010006400C192101051105 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 1700010936830052FA171F4D82B014ED396DB955 RAPx MODE : 00 RAPx HASH : B8C3ADECFC997FCD8081D3DEAF870B8C RAPx ROID : 4B9B75103E691FF8 CMT 1ST Boot OK Boot not Found: ASIC not Supported CMT 2ND Bt: ASIC not Supported BAD BOOT ERR: CMT 2ND Boot Rebooting Mobile jaf log FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR72_09w20.10 25-08-09 RM-504 (c) Nokia HW version: 0802 PCI version: RFIC version: DSP version: APE SW Core version: V 11.0.054 APE Variant version: V 11.0.054 APE Test version: rm504_ENO_x_09wk19v0.080 Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: CGL156791 Product code: 0578172 Module code: Basic production code: 0573512 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358253031689972 IMEI spare to net: 3A 85 52 03 13 86 99 07 IMEI SV to net: 33 85 52 03 13 86 99 07 F6 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-504.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0578172 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\ Searching for default location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_11.0.054_prd.core.C00 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_11.0.054_prd.rofs2.V19 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM-504_11.0.054_C02_prd.rofs3.fpsx APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-504\RM504_11.0.054_002_000_U001.uda.fpsx Done! Backing up CRT data... Setting FLASH MODE FAST PHONE detected! Error finding cmt boot file... Failed to backup CRT... Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\358253031689972_CRT_backu p_18231512.pm Done! Backup LCK OK! Reading SW version...ICPR72_09w20.10 11.0.054 Booting phone... FAST PHONE detected! CMT Boot Data: Asic ID: 000000010000022600010006400C192101051105 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1700010936830052FA171F4D82B014ED396DB955 HASH: B8C3ADECFC997FCD8081D3DEAF870B8C00000000 ROM ID: 4B9B75103E691FF8 Error finding cmt boot file... mx key also same error |
12-15-2009, 19:36 | #5 (permalink) |
Freak Poster Join Date: Sep 2008 Location: dubai
Member: 851014 Status: Offline Sonork: 6655 Thanks Meter: 21 | hello mr see here ur log >>>>> ur con fing key is 000000000000 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 now u need backup pm writte then ur phone is ok >>>> good luck how to make it ??? go here 1. c: drive 2. program files 3. odeon 4.jaf 5.progDAta and see here have ur imei ?? writte it with jaf box good luck |
12-21-2009, 14:48 | #8 (permalink) |
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | About switching off when making calls or incoming calls,Solution is on the HWK support. Check the pdf file about the 5530. It s a problem on some revisions. The top small belt near the touch ic or near the hear piece.REPLACE IT. Threat can be Closed ..... |
12-22-2009, 20:58 | #11 (permalink) | ||
No Life Poster Join Date: Feb 2006 Location: CAIRO Age: 37
Member: 237684 Status: Offline Thanks Meter: 66 | Quote:
i have the same prop i read all posts but i cant understand is this soft ware or hard plz help | ||
nokia 5530 auto off when making call | vertex777 | Nokia Base Band 5 ( BB-5 ) | 13 | 03-01-2012 11:05 |
8210 turn off when make call | askuqi | Nokia Hardware & Hardware Repair | 2 | 12-02-2003 15:30 |
3110 phone is switching off when making call | anry | Nokia Hardware & Hardware Repair | 4 | 09-06-2002 00:13 |
motorolla auto power off when making call | HITGSM2001 | Motorola Hardware Repair | 4 | 06-17-2002 05:43 |
3310 switch off when make call, but battery 2 segments | Vicky | Nokia Hardware & Hardware Repair | 2 | 02-05-2002 17:01 |
