Universalbox Universalbox Official support area |
07-30-2009, 11:55 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 707712 Status: Offline Thanks Meter: 4 | I need urgent help w810 cid 49 with 5 locks l used setool box to identify the it says (simlocks not detected) and when l use universalbox this is also the logsTUMTSReadInfoThread 2.7.8.2174 started at: 2009/07/30 10:31:28 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3.95V is in range of: 4.00V ±10.0% Output power at Line2 4.72V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Trying to send loader... OTP IMEI/CID/PAF: 356574-01-******** / 49 / 1 First FlashID: 897E Phone Color: RED. Phone CID: 49. Leaving test mode... Output power at Line1 3.95V is in range of: 4.00V ±10.0% Output power at Line2 4.74V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Entering explorer mode... OTP IMEI/CID/PAF: 356574-01-******** / 49 / 1 Initializing GDFS... Hardware ID: 040 GDFS IMEI/CID/PAF: 356574-01-******** / 49 / 1 Lock Code: Default (0000) LangPackage: S_ASIA_LEVAN CDA: CDA102555/110 Revision: R2A Leaving test mode... -------------------------------------------------------------------------------- TUMTSReadInfoThread 2.7.8.2174 finished at: 2009/07/30 10:32:54 Done. could someone help me to unlock this phone. thanks |
07-30-2009, 23:43 | #3 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | just do the unlock bro and 5 locks will be resolved...click the unlock tab and follow onscreen guide.good luck and post logs result... |
10-07-2009, 10:44 | #9 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 682885 Status: Offline Thanks Meter: 69 | scrpit if u unlocked this phone and then problem occured u can simply do this by re writing the imea scrpit backup and for free 2 min job problem solved phone will be locked to original network then unlock again. |
10-07-2009, 10:54 | #11 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Dubai
Member: 703206 Status: Offline Sonork: 100.1601193 Thanks Meter: 412 | Quote:
k310 cid 49 ALL 5 locks closed | azeem781986 | SETool2 | 5 | 08-21-2009 09:26 |
W810 CID 49 - How to unlock? Please Help | Soulja88 | SETool2 | 13 | 07-31-2009 17:59 |
Need help, urgent ~~ K550i cid 49 change cid 52 | jack_ho | Sony Ericsson | 2 | 07-22-2008 10:22 |
W810 CID 49 Strange Problem ??? | ..::AppleLinks::.. | Cruiser Suite | 9 | 10-31-2006 15:02 |
something error when flashing W810 cid 49 | CONG YANG | Universalbox | 1 | 08-11-2006 21:41 |
