Old 09-30-2011, 05:34   #1 (permalink)
ashokassag's Avatar
Member: 762520
Thanks Meter: 95
2700 restart problem
i have one 2700 restart problem i have flashed the handset with latest flash
file but the problem is same can any one help me
The Following User Says Thank You to ashokassag For This Useful Post:
Old 09-30-2011, 05:58   #2 (permalink)
Member: 1629736
Sonork: aayushjaiswal
Thanks Meter: 272
Hello sir u check bsi voltage
Old 09-30-2011, 06:01   #3 (permalink)
Member: 356823
Sonork: 100.1597345
Thanks Meter: 3
2700 restarting
replyse blutooth ic .................................................. .....................
Old 09-30-2011, 08:01   #4 (permalink)
Member: 1657686
Thanks Meter: 13
Brother,
May be water locked, just clean it and specifically have a look at Blutooth IC area , clean this area and rehot . it may be worked out.
If your mobile able to read the mobile info part completely then it will be hardware problem 100%.
Old 09-30-2011, 08:14   #5 (permalink)
Member: 1651577
Thanks Meter: 5
repair sd man.by mx key.i repair many time by mx key..do it tested by me
Old 11-08-2011, 21:15   #6 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
ha ha ha ha ha........................ its not same case boys try frist and try to post your successfuly expreriance Logs,,,,,, I did sooooo
Old 11-08-2011, 21:57   #7 (permalink)
Member: 1628887
Sonork: 100.1648746
Thanks Meter: 70
at fast you do job,after give your answer........]pls change the keypad ic mb 80%%%%%%%%ok............
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.14753 seconds with 9 queries
