10-28-2007, 21:04 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Dubai, UAE
Member: 4929 Status: Offline Sonork: 100.37251 Thanks Meter: 238 | Installation of v02.06.000 without problem Single user: 1. Install - HWK_Support_Suite_Setup_v02.06.000.exe (4408 KB) 2. Run Client 3. Install - HWK_Suite_Setup_v02.06.000.exe (51445 KB) Multiple User: (want to use more than 1 hwk in same pc) 1. Install - HWK_Support_Suite_Setup_v02.06.000.exe (4408 KB) 2. Run Client and update all hwk 3. Install - HWK_Suite_Setup_v02.06.000.exe (51445 KB) 4. if gives error when On 2nd, 3rd, etc hwk , install setup agian and "repair". |
The Following User Says Thank You to Hams For This Useful Post: |
10-29-2007, 10:06 | #7 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | It seems that your error is because of not installed, but copied from one pc to other software. I got same error after trying to launch dctx on other pc, as I have NAS in my network and installing all on it. Would be perfect if that security we could bypass. B.R. Alkapone |
10-29-2007, 10:39 | #8 (permalink) |
Freak Poster Join Date: Jul 2005 Location: In Front All of You Guys
Member: 166078 Status: Offline Thanks Meter: 21 | INSTALLATION HWK Suite Setup V02.06.000 NO ERROR, NO PROBLEM ANYMORE After I`m finish to install HWK_Suite_Setup_v02.06.000.exe succesfully and I run Update Client HWK v02.06.000 result is succesfull complete. BIG THAX`S TO HWK TEAM!!!!!!!!!! ---------- HWK upgrade started:5:18:47 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 57XXX -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-B411D22XXXXXXXXXX -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication successfull. Checking upgrade client version... Your upgrade client is up-to-date. Upgrading HWK... HWK upgrade process completed. ---------- HWK upgrade finished:5:19:15 PM ---------- B.R "Doglag" |
10-29-2007, 15:53 | #9 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | No need to bypass, I will give you solution. Run HWK Update client against each UFS+HWK if you have not already done so, then run HWK Setup Suite, after initial progress bar at next screen can quit, all UFS+HWK are then authorised for using the software. Odia. |
how you can use UFS_Suite_Setup_v03.06.000 without hwk | DIGITAL BABU | Twisterflasher | 5 | 07-09-2014 14:42 |
HWK v02.07.000 Installation & Non Authorised Tool Problem 100% Solved | ..::Mobile Smoker::.. | HWK | 3 | 05-21-2008 08:42 |
NEW HWK v02.06.000.exe | ashrafcell | HWK | 4 | 12-31-2007 09:43 |
Tested and 100% solution to install new HWK_Suite_Setup_v02.06.000.exe | Unlocker AL | HWK | 23 | 12-21-2007 01:54 |
v02.06.000 is dangerous for BB5 | .:bono:. | HWK | 34 | 12-04-2007 19:19 |
