Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 04-19-2015, 16:27   #1 (permalink)
Member: 2377297
Alcatel onetouch POP7 P310x stock rom
Hello gsm
i need stock frimware for alcatel onetouch pop7 p310x
Thnx
Old 04-19-2015, 20:02   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by eljokar_321 View Post
Hello gsm
Thnx
Restore your tab with factory OTU Updater - get it HERE
select P310 ....
p.s. can you write original PID from sticker ? (P310X-2xxxxxx),
because there are few different models (4Gb Rom, 8Gb Rom, 16Gb Rom, depending on region).
EDIT: 2 different versions for Egypt exists (I hope it's same language as in S.Arabia),
fist with 4Gb ROM, second with 8Gb ROM :
******* P310X 16G****************
P310X-2[X=A,B]ALAE4
******* P310X 8G ****************
P310X-2[X=A,B]ALAE2
or you need some other PID (PID = Product ID, ie: P310X-2AALEG1)
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 04-19-2015, 22:44   #3 (permalink)
Member: 2377297
Thnx for replay i use this otu updater . put its take along time . My tablet is p310x 8G its ok saudi or egypt its same arabic
Otu tool talk one day for recover my tablet so if you can give me link to have the stock rom I will be thankful
Old 04-20-2015, 21:05   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Download your ROM File - HERE
SPFT is standard, tablet is MT6582, so you can use v3 or v5 ...
post results.
b.r.
Alex
__________________
The Following 5 Users Say Thank You to Brka For This Useful Post:
Old 04-21-2015, 06:42   #5 (permalink)
Member: 2377297
thanx brka. is the flash tool with the rom file . and how i flash the rom ?
Old 04-21-2015, 20:59   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
SPFlashTools - HERE
- Unpack ROM (all files in one folder)
- Unpack SPFT
- Start SPFT, option "load scatter",
- Browse into rom folder, load scatter (only .txt file)
- Press DOWNLOAD, and connect powered off phone/tablet to usb cable
- Wait to finish, after done start phone/tablet.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 04-24-2015, 23:25   #7 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 431
Hello, I need to Polish language Tablet
Old 04-25-2015, 15:04   #8 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Change pid in pro_info and use otu updater
__________________
Old 04-25-2015, 15:14   #9 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 431
My English is not so good. You can do this to me? I would be very grateful.
PID: 2ARGPL1
Old 04-25-2015, 16:39   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
PID: 2ARGPL1
If you manage to read pro_info from it, sure, I can edit it for you.
I wrote in many threads how to read/write pro_info
(search, read, check sticky threads)
All you need is SPFT and Scatter file for that particular model.
b.r.
Alex
__________________
Old 04-26-2015, 09:47   #11 (permalink)
marcin7904's Avatar
Member: 290272
Thanks Meter: 431
Can you describe how to do it.
Old 04-27-2015, 18:25   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Already described, but lets do it again, until I make new sticky thread :
Tools needed :
- SPFlashTools
- Scatter file (for desired product, for this case - scatter from rom I posted already)
- USB Cable
Before how to, let's check whats inside scatter file :
partition_index: SYS3
  partition_name: PRO_INFO
  file_name: NONE
  is_download: false
  type: NONE
  linear_start_addr: 0x1500000
  physical_start_addr: 0x100000
  partition_size: 0x300000
  region: EMMC_USER
  storage: HW_STORAGE_EMMC
  boundary_check: true
  is_reserved: false
  operation_type: PROTECTED
  reserve: 0x00
What can we see here ? starting address, and length of partition.
Example is for partition that we need - pro_info
Now ...
How-To :
- Start SPFT
- Use attached scatter file, option "scatter-loading", load file
- Tab "Read Back", option "ADD"
- Double click on it, select save location for file, select name (pro_info.bin)
- Input start address : 0x1500000 , length : 0x300000
- Press button "READ BACK"
- Connect powered off phone/tablet to usb cable
- Wait for finish.
You have readed pro_info file .... upload to some sharing site, ie: mediafire, zippyshare, and post link here,
I will show you what next.
b.r.
Alex
__________________
Old 08-10-2015, 16:03   #13 (permalink)
Member: 2442221
alcatel one touch POP7 p310X -> 16Gig
hi
i have alcatel one touch POP7 p310X -> 16Gig
Does not matter ROM with 8GB model?
Old 08-10-2015, 23:41   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by tubreh View Post
hi
On most tablets, factory updater allows updating/restoring.
Why don't you try that first, before anything else ?
Download OTU Updater - HERE, install it,
select correct model, and follow the instructions.
b.r.
Alex
__________________
Old 08-22-2015, 07:45   #15 (permalink)
Member: 2442221
hi
my tablet viruses by : "monkey test" and "TimeService"
They will not be erased even by Factory Reset.
and i think there are one way for remove viruses"
flashing Rom an install stock Rom.
In the event that my tablet is : P310X 16GIG
(i'm sorry for my weak English language)
Page generated in 0.28380 seconds with 9 queries
