Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
02-01-2016, 22:10 | #46 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2523397 Status: Offline Thanks Meter: 0 | |
02-01-2016, 23:21 | #47 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | As stated in specs, tablet have 3G connectivity, intended for DATA connection. In theory, you can try to make it into "Phone", google for PHONE.APK, and install it in tablet, if it makes call and works ... great, you have it b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
02-03-2016, 06:57 | #48 (permalink) |
Member: 2523397 Status: Offline Thanks Meter: 0 | In South Africa, vodacom update firmware for Alcatel OT POP 7, "there is a firmware update available for you to have dialer and phone" and "Once this is done, you should be able to make calls using the Phone application on the menu list and dialing as per normal." So, i want to change PID with this South Africa firmware. i try with phone apk and application is not installed, because "An existing package by the same name with a conflicting signature is already installed". For change is necessary to root my device. i connected my tablet again in OTU and find another package, but when started, after 1 hour, it's the same firmware. I deleted some application and disable another one and i try OTU again. Find packages to download and .. same firmware. From the tablet software is up to date(from both wifi or SIM). Last edited by Brka; 02-04-2016 at 20:42. Reason: merged posts |
02-04-2016, 20:45 | #49 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | South Africa (ZA) PID's : Code: P310X-2[X=A,B]ALZA1 -- Should be RETAIL PID, no brandings P310X-2[X=A,B]VDZA1 -- This is probably Vodacom branded See what will happen. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
02-21-2016, 10:52 | #51 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Cape Town
Member: 1979291 Status: Offline Thanks Meter: 18 | Hello Brka i have one P310x it stuck on vodacom logo and there is no sticker at the back please help me to bring it back in menu what should i do now , would really appreciate your help **** EDIT : i upgraded P310x with OTU butt still hang on logo is there anyway to solve this problem please help me out Last edited by Brka; 02-21-2016 at 22:23. Reason: multiple posting |
02-21-2016, 19:02 | #52 (permalink) | ||
Member: 163 Status: Offline Thanks Meter: 7,787 | Quote:
Backup nvram, full format, write pro_info, Use otu updater again. If still the same, then its hardware problem. Quote:
OPEN YOUR EYES AND READ WHOLE THREAD. B.r Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 02-21-2016 at 22:22. | ||
02-22-2016, 17:05 | #53 (permalink) |
Member: 1979291 Status: Offline Thanks Meter: 18 | my p310x had virus so i was flashing with p310x firmware one i read from another p310x so when it reached on 30% then flash stopped i tried OTU i flashed with arabic firmware using SP tool bt no luck please can you help me to get out of this mess THANKS |
02-22-2016, 17:26 | #54 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | Full format, reflash. If still problems, change pc, charge battery, etc. B.r. Alex
06-19-2016, 15:07 | #58 (permalink) |
Junior Member Join Date: Mar 2008
Member: 720353 Status: Offline Thanks Meter: 1 | I load 8GB ROM file for 4GB version tablet and it works fully normal, system show normal 2GB internal memory. |
The Following User Says Thank You to basstec For This Useful Post: |
08-27-2016, 15:57 | #60 (permalink) | |
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
