Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
04-19-2015, 20:02 | #2 (permalink) | |
Member: 163 Status: Online Thanks Meter: 7,785 | Quote:
select P310 .... p.s. can you write original PID from sticker ? (P310X-2xxxxxx), because there are few different models (4Gb Rom, 8Gb Rom, 16Gb Rom, depending on region). EDIT: 2 different versions for Egypt exists (I hope it's same language as in S.Arabia), fist with 4Gb ROM, second with 8Gb ROM : ******* P310X 16G**************** P310X-2[X=A,B]ALAE4 ******* P310X 8G **************** P310X-2[X=A,B]ALAE2 or you need some other PID (PID = Product ID, ie: P310X-2AALEG1) b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 04-19-2015 at 22:16. Reason: added info | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
04-19-2015, 22:44 | #3 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2377297 Status: Offline Thanks Meter: 0 | Thnx for replay i use this otu updater . put its take along time . My tablet is p310x 8G its ok saudi or egypt its same arabic Otu tool talk one day for recover my tablet so if you can give me link to have the stock rom I will be thankful |
04-20-2015, 21:05 | #4 (permalink) | |
SPFT is standard, tablet is MT6582, so you can use v3 or v5 ... post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 5 Users Say Thank You to Brka For This Useful Post: |
04-21-2015, 20:59 | #6 (permalink) | |
- Unpack ROM (all files in one folder) - Unpack SPFT - Start SPFT, option "load scatter", - Browse into rom folder, load scatter (only .txt file) - Press DOWNLOAD, and connect powered off phone/tablet to usb cable - Wait to finish, after done start phone/tablet. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
04-25-2015, 15:04 | #8 (permalink) |
Member: 163 Status: Online Thanks Meter: 7,785 | Change pid in pro_info and use otu updater
04-25-2015, 16:39 | #10 (permalink) | |
I wrote in many threads how to read/write pro_info (search, read, check sticky threads) All you need is SPFT and Scatter file for that particular model. b.r. Alex
04-27-2015, 18:25 | #12 (permalink) |
Member: 163 Status: Online Thanks Meter: 7,785 | Already described, but lets do it again, until I make new sticky thread : Tools needed : - SPFlashTools - Scatter file (for desired product, for this case - scatter from rom I posted already) - USB Cable Before how to, let's check whats inside scatter file : Code: partition_index: SYS3 partition_name: PRO_INFO file_name: NONE is_download: false type: NONE linear_start_addr: 0x1500000 physical_start_addr: 0x100000 partition_size: 0x300000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED reserve: 0x00 Example is for partition that we need - pro_info Now ... How-To : - Start SPFT - Use attached scatter file, option "scatter-loading", load file - Tab "Read Back", option "ADD" - Double click on it, select save location for file, select name (pro_info.bin) - Input start address : 0x1500000 , length : 0x300000 - Press button "READ BACK" - Connect powered off phone/tablet to usb cable - Wait for finish. You have readed pro_info file .... upload to some sharing site, ie: mediafire, zippyshare, and post link here, I will show you what next. b.r. Alex
08-10-2015, 23:41 | #14 (permalink) | |
Why don't you try that first, before anything else ? Download OTU Updater - HERE, install it, select correct model, and follow the instructions. b.r. Alex
08-22-2015, 07:45 | #15 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2442221 Status: Offline Thanks Meter: 0 | hi i have alcatel one touch POP7 p310X -> 16Gig my tablet viruses by : "monkey test" and "TimeService" They will not be erased even by Factory Reset. and i think there are one way for remove viruses" flashing Rom an install stock Rom. In the event that my tablet is : P310X 16GIG Does not matter ROM with 8GB model? (i'm sorry for my weak English language) |
