12-29-2007, 11:35 | #1 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: Austria
Member: 5641 Status: Offline Thanks Meter: 72 | 5300 unlock problem Quote:
12-29-2007, 11:47 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | mate check its interface ic probably broken or drysolded better to change it then unlock,,,,,,ur prob willl be solved tested one 6300 with broken crystal giving same error after change its unlocked fine,,,, br khalid |
12-31-2007, 15:58 | #8 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | thanks supporter... is there any option of updates for unlocking thru key code .... coz....lot of handsets coming with fbus count closed but have some remaining attempts in key code count... thanks sir... |
01-01-2008, 07:48 | #9 (permalink) | |
Member: 78619 Status: Offline Thanks Meter: 297 | Quote:
br khalid | |
01-01-2008, 08:07 | #10 (permalink) | ||
No Life Poster Join Date: Sep 2004 Location: UK, London
Member: 82666 Status: Offline Sonork: 100.108210 Thanks Meter: 284 | One More BIG Problem in MT Box Quote:
Yes Mate i agree with u i have also face same problem.....Where should i understand it's Only Defrent Chip problem ....Bcoz i have seen this problem only in SOME ROGER Network & Maxicon Network 5300 Fones Quote:
ONE MORE Big problem in MT+MT Light interface Some time when u connect write TP in 1st Atempt MSG shown ALL ATEMPT USE and Sim status set on 10/10 after that some fone Accept TP and unlocked but most of them not Accepting tp with out writting RPL....... Strange thing bcoz same TP work 2nd time but 1st time it's make fone Sim Status 10/10 ........ Problem Noted in few models ===================== N95 6300 5200 5300 MT Team need to fix this Problem Thanks | ||
01-01-2008, 09:13 | #11 (permalink) |
Freak Poster Join Date: May 2007
Member: 519206 Status: Offline Thanks Meter: 11 | did 4 5300 yesterday , only 3 unlocked on first atempt and the 4th one unlocked on 2 atempt after writing back and the 4th one will go local, but not read anything with usb, so i used fbus and had to solder cable on clk+data |
01-10-2008, 08:05 | #14 (permalink) |
Member: 78619 Status: Offline Thanks Meter: 297 | post simlock state man,,,,,,,,,,,,,,, either u have couter 10/10 or config key FFFFFFFFFFF............ if it is so and have good backup write it back if dont have backup go for rpl............................ if that boths r not the case .....then opprator is 334020 then u dont have the solution yet......... br khalid |
5300 unlocking problem | preshaust | J.A.F. V-SPEC | 5 | 01-15-2009 20:30 |
E50 new flash chip and 5300 unlock problem | kin88 | BB5 Box by D.K. | 1 | 12-07-2007 19:21 |
5300 unlock problem | koa | MT-BOX | 2 | 10-17-2007 09:00 |
5300 unlock problem | rutar | MT-BOX | 13 | 10-06-2007 19:40 |
5300 unlock problem | NiceLys | UID - Box | 1 | 09-18-2007 17:53 |
