12-21-2007, 13:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 49
Member: 88410 Status: Offline Thanks Meter: 1 | Help beat the revision=F on Vista problem Heres the score - revision=F is definitely in the Griffin.ini file. If i close the ini file and re-open it is still there, so it's definitely saved it. - I'm using the non-server required 1.40_2 version of the software - Every phone still has "W" at the begininning when unlocking! - I've tried deleting Griffin.ini and re-installing - I've tried deleting revision=F, saving, then putting it back again - I've searched to make sure there is no other Griffin.ini on the PC - I've checked to see if there is another "revision=..." in the ini file I've run out of ideas but there are other users using Vista without issue so I call on the help of others to get this finally sorted! HELP! FWC |
12-21-2007, 15:15 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | bros dont put revision=F ON NEW STANDALONE IS WORKING PERFECT U WILL SEE STANDALONE ALONE TEXT AND IS AUTOMATIC REFISION F...INSTALL VER 136..141 AND COPY AND PASTE 1412 ...IS WORKING ON VISTA SUCESSFUL UNLOCK N95 NOW...IT WILL NOT ALLOW U 2 MODIFY IF U WANT 2 DOFIFY URSELF..BR |
12-21-2007, 15:36 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | Quote:
revision=F is needed always !!!! | |
12-21-2007, 15:38 | #4 (permalink) | |
use search to find another copy of griffin.ini and repalce with this from instalation and update.Need to have installed 1.36,1.41,1.41.2 | |
12-22-2007, 02:50 | #5 (permalink) |
Member: 88410 Status: Offline Thanks Meter: 1 | Ahah! :-) Search results show 2 Griffin.ini files: C:\Program Files\GriffinTeam\MT-Box and also... C:\Users\**USERNAME**\AppData\Local\VirtualStore\P rogram Files\GriffinTeam\MT-Box\ So I've edited the second one(no revision=F was here!) and will test out tommorrow! I think this will do it - if it does then that's the location Vista users need to be editing! Now the interesting thing is that Vista search is very funny, by default it only searches indexed locations so therefore it wasn't doing a full hard-drive search which explains why this second(non-indexed) file wasn't being found. If doing the search then you MUST use advance search option and make sure "Location" is not set to "Indexed Locations" - select the Drive C instead! Also a good explanation can be found here: http://www.randyrants.com/2007/02/vista_tip_virtu.html FWC Last edited by freewaycomms; 12-22-2007 at 02:59. Reason: Added Vista search information |
12-22-2007, 03:03 | #6 (permalink) |
Member: 88410 Status: Offline Thanks Meter: 1 | Another here: http://echerng.net/blog/2007/08/31/t...-virtualstore/ Sorry for 2nd post - it wouldnt let me edit again! FWC |
Dell TrueMobile 355 connectivity problems on Vista - SOLVED! | heathcliff74 | Bluetooth-Software | 2 | 08-31-2008 20:05 |
Problems with Driver, can't install Drivers on VISTA and XP | carlito79 | Infinity-Box | 10 | 05-24-2008 18:49 |
i need help 6230I THE PROBLAM IS ON &0FF | nasir iqbal | Nokia Hardware & Hardware Repair | 0 | 08-09-2007 14:09 |
KulanKendi doesn't work on Vista PC and tried to connect to the Sony phone P990i | Mr.Dextor | KULANKENDI Server | 1 | 03-05-2007 21:54 |
Is it possible to revise the sbn file to enable the message report on T28s? need help | subaru | Old Ericsson Phones & Sony Phones | 0 | 10-05-2003 01:27 |
