01-02-2008, 16:33 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: malaysia Age: 40
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | Need Help 6300!! F 05.00/27-04-07/RM-217/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\359544010242497.pm nBackup file already exists! SKIPPING backup ================================= Using fixed version support !!! V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 359544010242497 TPs OK SIMLOCK NOT INITIALIZED! (empty board/no simlock record) V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 359544010242497 Failed to Read |
01-02-2008, 16:39 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Quote:
BR, Tito Millo | |
01-03-2008, 16:38 | #4 (permalink) |
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | here the log writting RPL Phone is in: Test mode Model: RM-217 ( 6300) V 05.00/27-04-07/RM-217 (c) Nokia. Production serial number DQA252538 Product code 0546425 Module code 0203166 Basic production code 0537040 Flash code Order number Long production SN MCU SW V 05.00/27-04-07/RM-217/(c) Nokia. HW 1000 PCI RFIC 17211721 DSP pb06w14v51 PPM V 05.00/27-04-07/RM-217/(c) Nokia. /S Retu 32 Tahvo 53 Content Pack Content: s/V 05.00/09-05-07/RM-217/(c) Nokia. / IMEI: 359544010242497 WARNING: VPP pin is not connected, disabling VPP. IMEI: 359544010242497 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... CMT Send NPC Certificate CMT Send HWC Certificate CMT Send CCC Certificate Phone Type: BB5 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.90V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Model: RM-217 ( 6300) V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 359544010242497 Simlock send - FAILED! SuperDongle send - FAILED! |
01-03-2008, 17:23 | #5 (permalink) |
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | After wirte RPL and unlock again F 05.00/27-04-07/RM-217/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\359544010242497.pm nBackup file already exists! SKIPPING backup ================================= Using fixed version support !!! V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 359544010242497 TPs OK SIMLOCK NOT INITIALIZED! (empty board/no simlock record) V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 359544010242497 Failed to Read |
01-04-2008, 09:26 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | Quote:
SuperDongle send - FAILED! Try THIS solution. Phone is RAP. If not help read HERE . | |
need help 6300 | rangan_kumar | Nokia Base Band 5 ( BB-5 ) | 6 | 09-03-2009 22:12 |
Need help 6300 phone resticted | danau_ranau | J.A.F. Plus | 11 | 11-21-2008 11:25 |
need help 6300 problem | adnan8284 | Nokia Base Band 5 ( BB-5 ) | 5 | 11-20-2008 17:27 |
need help 6300 | lauznis1 | BB5BOX | 6 | 03-23-2008 16:08 |
need help 6300 | @sEPH | Nokia Base Band 5 ( BB-5 ) | 0 | 06-28-2007 09:45 |
