03-04-2008, 08:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Muaradua_sum_sel Age: 46
Member: 671476 Status: Offline Thanks Meter: 31 | Need help 6300 phone resticted this is read info from JAF FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.00 27-04-07 RM-217 (c) Nokia. HW version: 3007 PCI version: RFIC version: 17211721 DSP version: pb06w14v51 PPM version: V 05.00 27-04-07 RM-217 (c) Nokia. X BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: x V 05.00 09-05-07 RM-217 (c) Nokia. Production serial number: KEQ571125 Product code: 0537632 Module code: 0203166 Basic production code: 0537040 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356401013619887 IMEI spare to net: 3A 65 04 01 31 16 89 08 IMEI SV to net: 33 65 04 01 31 16 89 08 F8 LOCK STATUS: CONFIG KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0537632 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! can you help my problm sir..............? |
The Following User Says Thank You to danau_ranau For This Useful Post: |
03-04-2008, 09:00 | #2 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: rajabrothers communications Age: 43
Member: 155773 Status: Offline Sonork: 1606514 Thanks Meter: 87 | Quote:
if u have pm backup this phone write it if u dont have this u need rpl........... br raja | |
The Following User Says Thank You to rajabrotherscom For This Useful Post: |
11-05-2008, 05:39 | #7 (permalink) |
Freak Poster Join Date: Oct 2008 Location: JUST IMAGINE
Member: 882865 Status: Offline Sonork: 100.1614808 Thanks Meter: 17 | ya thank u very much sir but which u r telling that rpl calc i can use at once or all models when i want, than where i have to buy can u tech meeee plzzzzzzzzzzzzzzzzzzz |
11-20-2008, 10:04 | #9 (permalink) |
Member: 882865 Status: Offline Sonork: 100.1614808 Thanks Meter: 17 | [ ll but which u r telling that rpl calc i can use at once or all models when i want, than where i have to buy can u tech meeee plzzzzzzzzzzzzzzzzzzz |
6300 phone resticted?????? | omkarvitekar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-02-2010 15:38 |
need nokia 3110c phone resticted bro soln | rajendrakumar | Universalbox | 3 | 12-09-2009 19:54 |
need help 6300 | lauznis1 | BB5BOX | 6 | 03-23-2008 16:08 |
Need Help 6300!! | ..::M-GSM::.. | MT-BOX | 5 | 01-04-2008 09:26 |
need help 6300 | @sEPH | Nokia Base Band 5 ( BB-5 ) | 0 | 06-28-2007 09:45 |
