x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-11-2002, 02:12 | #1 (permalink) |
Insane Poster Join Date: May 2002 Location: Netherlands Age: 41
Member: 11803 Status: Offline Thanks Meter: 0 | m35i died after SW upd v21 please help after SW update to v21 (stupid thing to do, I know now) After switching on phone I get:" Phone blocked Network-CODE" I tried to write-back a full v18 (origional backup) flash with Martech x35 service Tools. Phone is completely death now! Please help! Trailer. |
06-11-2002, 04:28 | #2 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Portugal Age: 37
Member: 6080 Status: Offline Thanks Meter: 4 | You can't downgrade the version of your Siemens When appears Phone blocked Network-CODE you must unlock with ZiemensG3 Now you can repair your phone with ****** or Landy instructions Regards Sorry my english |
06-11-2002, 05:37 | #4 (permalink) |
Member: 6080 Status: Offline Thanks Meter: 4 | Landy Page If you need password to download use this USER NAME: mobile PASSWORD: elibom Regards and good luck |
06-11-2002, 05:43 | #5 (permalink) |
Member: 6080 Status: Offline Thanks Meter: 4 | Solution by rivend If you don't understand the Landy solution you have Rinvend solution "THIS SIMPLE REPAIR I HOPE MORE EASY TO USE. For ALL people always asking and searching about this topic, This is a solution i use for repair and your all must know how to use (PLS LEARN by ur SELF). This solution i get while try to downgrade ver24 to ver21. (Ver24 cannot change imei if u change with lead your phone get error and u must use workshop 1.22 pro to repair) 1. USE MARTECH 1.7 TO WRITE FULL FLASH (CHOOSE X35 FULL FLASHER (X35 VER 05) TO WRITE (THIS FULL FLASHER YOU CAN DOWNLOAD FROM LANDY PAGE)). UNTIL FINISH --> NEXT 2. FLASH YOUR PHONE WITH WINSWUP and USE X35 VER 0503 --> NEXT 3. USE ZIEMENS SOFTWARE 1.22 BY PRO AND PRESS "CEE_REPAIR" (THIS JUST TRY REPAIR ANY DAMAGE BY FLASHER (REPAIR "SERVICES MODE") REMEMBER YOUR PHONE STILL DEAD) --> NEXT 3. TRY YOUR PHONE WITH MARTECH 1.7 FOR SURE IF YOUR PHONE CAN CONNECT TO "SERVICES MODE" (THE WORDs UP ON PHONE SCREEN) --> NEXT 4. IF OK FOR "SERVICES MODE" USE X35EE_UPLOADER AND USE RM0503.BIN (S35) or CM0503.BIN (C/M35) TO REPAIR YOUR PHONE EEPROM. (SOMETIME U MUST PRESS THE "ON" POWER REPEAT 3-5 TIMES UNTIL THE "SERVICES MODE" UP ON THE PHONE) --> NEXT 5. USE ZIEMENS 1.22 AGAIN TO REPAIR CLICK "CEE_REPAIR", NOW YOU GET WORKING PHONE AGAIN --> NEXT 4. USE IMEI CHANGER BY LEAD TO CHANGE IMEI BACK. --> NEXT 5. FINALLY U CAN USE X35 ANY FIRMWARE TO UPGRADE BUT YOU JUST CAN UP TO VERSION 21. CAUSE LEAD IMEI WRITER JUST SUPPORT UP TO VERSION 21 (AFTER VER21 YOUR PHONE WILL ERROR, PLEASE REPEAT PROCEDURE TO REPAIR) THIS SOLUTION TESTED ON S35i AND M35I (WORKS 100%) ALL SOFTWARE YOU CAN DOWNLOAD FROM LANDY PAGE For EEprom u can download from here" Regards Rinvend |
06-11-2002, 09:35 | #6 (permalink) |
Member: 11803 Status: Offline Thanks Meter: 0 | M35i died after SW upd v21 please help Thanks alot GSMCyber, I can switch on the phone again (lights up only, no info) After a few minutes it starts beeping for a few seconds. I flashed and updated it as mentioned Landys instructions, with sw v5. The EEprom is C489. I can't get this "x35Eeprom uploader" working (DOS prog) running WIN98SE. (proggy is not responding) The phone came alive after activating "CEE_Repair"(Ziemens x3x Series Workshop 1.22) I can't find Cm0503.bin (size 64kb) for uploading to the EEprom!! Please help me to finish this last stage, to get it working again! Trailer. |
06-12-2002, 01:04 | #8 (permalink) |
Member: 11803 Status: Offline Thanks Meter: 0 | M35i died after SW upd v21 please help Hello GSMCyber, Thanks again, for your answer. Maybe you can also give me some useful information, about using "x35Eeprom uploader" under WIN98SE. You can mail me here Greetz Trailer |
A1200 died after the jumper fl902, please someone help me | Valkensuit | Motorola Hardware Repair | 0 | 08-15-2008 20:24 |
GD55 main sw + LP needed please help!! | XenKo78 | Panasonic | 3 | 07-13-2003 14:01 |
Motorola dead after Kima 7.7...please, help! | Migeni | Motorola ODM | 39 | 10-03-2002 17:12 |
s35 dead after upgrading to v20 please HELP | majB | x1x to x45/x50 | 3 | 09-02-2001 18:12 |
