x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-09-2004, 17:38 | #4 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | Quote:
If you can't to find fubu v25, there is explanation how to relive your phone so you can flash it again with swup v25. | |
05-17-2004, 21:59 | #5 (permalink) |
Freak Poster Join Date: Oct 2003
Member: 40747 Status: Offline Thanks Meter: 0 | Hello Do This Flash Your Siemens With Any Full Flash From Another Working C35. Step 2 (use Freia) And Select Unlock Then Update Flash Imei And Write There The Original Imei From The Back Of Your Dead C35 Ur If You Do Not Know It Just Press Use Eeprom Imei. Tested 100 % |
06-07-2004, 01:37 | #10 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | If donīt wanna spend your life repairing your phone, donīt use FUBU. If your phone was killed during unlock, and u didnīt do anything to it yet, flash an update (winswup) and unlock again. PS: Using FREIA and as itīs a v25, u must select (new) C35 |
01-07-2005, 20:31 | #11 (permalink) | |
Freak Poster Join Date: Jan 2004 Age: 38
Member: 49668 Status: Offline Thanks Meter: 0 | Quote:
your solution works perfect, repaired phone Thanks | |
01-31-2005, 01:27 | #12 (permalink) |
Junior Member Join Date: Oct 2004 Age: 54
Member: 86999 Status: Offline Thanks Meter: 1 | Network problem My phone is showing no network . After registering the service provider I cant make calls with it. When I call says network blocked. I dont know why can anyone help me. hnetwork blocked |
02-01-2005, 08:43 | #13 (permalink) |
Member: 49668 Status: Offline Thanks Meter: 0 | Can't change C35i IMEI After unlock phone dead! Updated to version 25 & trying to unlock, but something got wrong! I can't change IMEI, always EEPROM IMEI corrupted, tryed many times Any solutions? Thanks |
03-07-2006, 14:26 | #15 (permalink) | |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | Quote:
i have downloaded winsup.. is there any update file i need ? i have checked ur website there are some eeprom files which one to use ? plz explain a little thnx and regards | |
C35 dead | Marig | x1x to x45/x50 | 3 | 10-10-2001 17:44 |
c35.........dead...... | stavros | x1x to x45/x50 | 1 | 07-25-2001 20:54 |
Solution for C35 dead after full falshing? | hiall | x1x to x45/x50 | 8 | 07-20-2001 13:21 |
C35 Dead after flashing MARTECH ??? Any solution working 100% | Raul | x1x to x45/x50 | 1 | 04-23-2001 20:29 |
C35 dead after upgrade an downgrade | the_viper | x1x to x45/x50 | 6 | 03-24-2001 11:49 |
