x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
03-19-2001, 10:14 | #1 (permalink) |
Junior Member Join Date: Mar 2001
Member: 3687 Status: Offline Thanks Meter: 0 | C35 dead after upgrade an downgrade Greets |
03-21-2001, 20:22 | #2 (permalink) |
No Life Poster Join Date: Jun 2000 Location: Bratislava.SR
Member: 1630 Status: Offline Thanks Meter: 1 | flashback (heh cool game wasnt it?) to v18, it will flash, dont worry, sometimes when the eegold appeared, i tried it next day and everything flashed fine right now (10 mins ago) i repaired a dead C35 with v18 and i am searching unlock solution.......) |
03-21-2001, 20:25 | #3 (permalink) |
03-22-2001, 21:49 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Portugal
Member: 2949 Status: Offline Thanks Meter: 0 | Sorry for the stupid question, but someone can explain me step by step how to upgrade/downgrade versions. I have Swupinstall , Swup191 and all the flashes needed but I do not know how to use them. I just need Swupinstall and only have to follow the instructions?? I only need the flash file that is also exec.?? What is Swup191 for?? If someone can take a minute to explain me I would be very greatfull. Thanks |
03-22-2001, 22:10 | #6 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Netherlands
Member: 3561 Status: Offline Thanks Meter: 1 | it's not hard... First make sure you have a full battery. Connect your phone to the cable and make sure it's turned on. Run swupinstall.exe (only need to do this once) tell it what language to use and what comport to use for flash software. Usually com 1 and english will do fine. You'll notice a swup.ini file is now generated. Use the flash.exe (named something like c3i_1201.exe) to upgrade your phone and follow instructions on screen. Your phone will shut down. When it sais something about egold trying to connect press the power on button for a short time. Than it takes about 10 minutes to flash your phone. |
C35 v18 dead after upgrade to v24 | gama_cell99 | x1x to x45/x50 | 2 | 04-17-2005 16:42 |
C35 dead after flash ???pls help??? | proxy_gsm | x1x to x45/x50 | 8 | 04-22-2004 16:19 |
c35 dead after write wong map help | bedjo | x1x to x45/x50 | 4 | 04-19-2002 04:11 |
Solution for C35 dead after full falshing? | hiall | x1x to x45/x50 | 8 | 07-20-2001 13:21 |
C35 Dead after flashing MARTECH ??? Any solution working 100% | Raul | x1x to x45/x50 | 1 | 04-23-2001 20:29 |
