E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
08-18-2006, 09:49 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 333305 Status: Offline Thanks Meter: 0 | Help converting an A57 to a C55 New user Mega32 here I bought a Siemens A57 , to use for sending SMS via a Microprocesor. I build a Serial Cable , and can send ATZ and get OK back. But the A57 doesn't reckognize most of the AT commands used for sending and receiving SMS I think i have read that the A-series doesn't support those commands. And that it might be possible to convert it to a C55 Could anyone here walk me through the conversion ??? I have downloaded : Freia15 & Freia18 and SiMoCo And i think i might have a picture of the testpoint to cut here http://people.itu.int/%7Eemartine/Te...ts/a55new.jpeg Is it the thin red line i have to cut ??? I need the C55 software and a step by step guide I will be verry thankfull for that If someone need my email addy for sending this , then please say so. TIA Mega32 |
08-18-2006, 14:23 | #2 (permalink) |
Member: 333305 Status: Offline Thanks Meter: 0 | Found a new "CutPoint" seems like it is not in layer2 , witch will make it easier http://senkron24.se.funpic.de/Test%2...stpoint8jb.jpg Can anyone confirm this ?? TIA Mega32 |
08-19-2006, 00:51 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Romānia
Member: 76629 Status: Offline Thanks Meter: 76 | Don't waste your time with testpoints, just buy a used C55 phone instead! The A57 flash content is very different from C55, and the C55 flash content WILL NOT WORK in a A57 phone! The only other flash wich will work on A57 is from A55 !! You could find a working C55 phone for 15-20 EUR! |
08-19-2006, 10:36 | #6 (permalink) | |
Member: 76629 Status: Offline Thanks Meter: 76 | Quote:
And NO, the PCB of A55 is different from the PCB of C55, just look at keypad, there is two keys more than A55: Up, Down, Left and Right! A55 have only Up and Down keys in the middle! | |
08-19-2006, 11:38 | #8 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
It is working and many times tested by me And C55 don't have 2 keys more. Keys from C55 are only other ordered. @Mega32 Cut testpoint, fullflash the phone with C55 FUBU and make "recalc all keys" withjoker. That's all. But better read EEPROM of your A57 first! | |
08-19-2006, 20:00 | #9 (permalink) |
Member: 333305 Status: Offline Thanks Meter: 0 | Guyzz thanx for the hints Any hints (links) to a C55 FUBU file that fits Joker ?? And ... Has anyone tried the new testpoint , on upper layer ?? It would be nice , not having to cut in 2'nd layer I have tried to read out , eeprom and battery files with freia. How do i do that with Joker ?? TIA Mega32 |
08-19-2006, 22:02 | #10 (permalink) | |
No Life Poster Join Date: May 2004 Location: Colombia Age: 35
Member: 64398 Status: Offline Thanks Meter: 153 | Quote:
Yes tested some times with A55@C55 And a 1000 times with A56@C56 | |
08-21-2006, 23:21 | #12 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | specialy a C55 FUBU for you. Flash it with freia and make unlock (unlock-->direct unlock-->use org. IMEI) after flashing. But don't forget to read A57 EEPROM before, coz save is save DOWNLOAD |
Help convert s60 v3 to s60 v5 | spkhmer | Nokia Multimedia | 0 | 10-25-2009 13:08 |
Lead plz help!! Converting W600i back to Red Certificate | akasim01 | Cruiser Suite | 7 | 10-18-2006 18:23 |
Help Convert A680 Sprint to be used on Verizon | yoshix003 | Various CDMA/TDMA Cell Phones | 0 | 08-07-2006 03:54 |
Help Convert V802se Brown to Red | momomo | Cruiser Suite | 1 | 08-23-2005 07:56 |
Help converting an S45 into an S45i | Drug_Store | x1x to x45/x50 | 9 | 11-28-2002 22:23 |
