Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 02-09-2004, 08:58   #1 (permalink)
Member: 215
Lightbulb URGENT!!! Need S56 fullflash
Hi!
Who have S56 fullflash?
Very need!
Best regards
Old 04-13-2004, 19:44   #2 (permalink)
Member: 61295
I have it, pm me if you still need it.
-albertr
Old 04-13-2004, 20:25   #3 (permalink)
Member: 61295
-albertr
BTW, I'm looking for a full copy of S56 eeprom, since I killed mine. Would appreciate any help....
-albertr
Old 04-13-2004, 20:29   #4 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
Write your fullflash! Where is the problem?
Old 04-13-2004, 21:08   #5 (permalink)
Member: 61295
Ahh, so fullflash includes eeprom area too? Damn, then my copy of fullflash is no good. Unfortunately, I made it *after* damaging eeprom. I had eeprom backup made before, but lost it. Shame on me... Anyway, here's what happened for ones who are curious. I didn't mean to play with the phone (that's why I didn't bother to make another backup, silly me), just thought of restoring old backup of eeprom block 71. But instead of writing S56's 71, I did C65's 71 into S56 (yes, I have both S56 and C56). How that could possibly happen and what I was thinking at the moment, I don';t know. Freia also didn't seem to care much of checking for appropriate phone model, etc. I got no warning, nothing. Anyway, what's done is done.
If someone can send me a copy of their S56 eeprom, it would be much appreciated. But now I'm getting worried if my flash was damaged beyond eeprom area? Is there any way to figure out where Freia wrote C56's block 71? Which area of eeprom it's supposed to go?
-albertr
Old 04-13-2004, 21:28   #6 (permalink)
Member: 61295
Ahh, great. Looks like in C56 eeprom starts from offset 0xFA0000 while in S56 it's at 0xFE0000. If so, block 71 in C56 could reside somewhere in 0xFA0000 - 0xFFFFFF area. Could anyone with Cingular S56 make a copy of area 0xFA0000 - 0xFDFFFF with Frea for me?
Thanks,
-albertr
Old 04-13-2004, 21:52   #7 (permalink)
Member: 61295
On a second thought, I'll probably need a fullflash (either Cingular or AT&T) anyway. Any help would be appreciated!
-albertr
Old 04-13-2004, 22:30   #8 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
U killed ur EEPROM! There is only one block in phone! So u need complete EEPROM to restore ur phone!
Old 04-13-2004, 23:49   #9 (permalink)
Member: 61295
So you say, if I write only one block to the phone, it won't just replace original block (at the same address), but erase all other blocks in eeprom?
BTW, I was using Siemens.EEPROM.Tool, not Freia, sorry for confusion...
Thanks,
-albertr
Old 04-14-2004, 00:10   #10 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
Yes. U will delete all other blocks and write only block 71. So be carefull with EEPROM Tool. But if u know what u have to do it is a very very good tool!
I know that
Old 04-14-2004, 16:36   #11 (permalink)
Member: 61295
Got a eeprom copy from a fellow board member (thanks Yuri!), restored my IMEI, and it's getting better. Phone boots now, I had to adjust contrast (it was not readable). But there at least one problem still exists - phone shuts itself after a few minutes, it's not fixed intervals, tho. It could last for awhile, or can shut down almost immediately...
Anyone knows what it could be? Maybe my battery sensor is not properly calibrated and needs adjustment (like contrast)? BTW, my battery is fully charged and phone shows it as a fully charged. Or my firmware was damaged (that's possible) and phone crashes? Or it runs crc check at spare time and detects some inconsistencies? Or my firmware (Cingular, v17) is not really fully compatible with copy of eeprom (v6, AT&T)?
Any ideas welcome.
Thanks,
-albertr
Old 04-14-2004, 19:17   #12 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
Write Fullbackup and try again!
Old 04-14-2004, 20:25   #13 (permalink)
Member: 61295
I wish I could....
Yes, that would be the best solution, unfortunately I don't have a good fullflash. Mine is borked....
-albertr
Old 04-14-2004, 21:05   #14 (permalink)
Member: 61295
Good news! Seemed to fix shutting off problem by replacing EEFul eeprom blocks with the original copies from my S56. Still EELite blocks are the ones sent to me by fellow S56 owner since original are lost. Phone seemes to be stable now, two hrs without shutting off and still counting... I keep my fingers crossed.
Now need to figure out how to make DES work with S56.... Any suggestions?
-albertr
Old 04-15-2004, 05:37   #15 (permalink)
Member: 61295
Ok, was not that easy. But looks like I might have an idea as why phone is crashing (btw, yes, it's still crashing with debug dump). Everytime that happens the phone was charging and battery was nearly fully charged. I think that it could be because the battery sensor calibration is a way off now and phone is trying to overcharge already fully charged battery? Could it be that there's an overcharge protection circuit exists that kicks in and shuts phone off? Would that make sense? If so, it hopefully could be fixed by re-calibrating the battery sensor?
On a positive note, RF calibration seems fine, no reception problems so far.
-albertr
need e300 fullflash urgently infogsm Trident/AGERE Platform 25 05-05-2007 00:12
Need C75 Fullflash Urgent lutechua S-Gold Based Phones 15 02-21-2007 21:53
C75 fullflash urgently need!!! Grissooo SST-Dongle 2 10-18-2005 14:44
s56 fullflash needed tomaszwl E-Gold Based Phones 3 09-05-2005 08:41
Urgently need Locked flex or fullflash from any locked to provider motorola acer phon balu_dark Motorola ODM 2 07-23-2005 17:55
Page generated in 0.26473 seconds with 9 queries
