plz help , unlock M65 !!!! i have M65, and made TP and have also Papua and SST 5.32 but both didn't unlocked it shown boot not loaded when i use "auto open all of papua, and sst dosen't read at all, i don't know if i did wrong steps so plz help me to use papua or SST and how to know M65 version thanks a lot |
Use search tool.. For view version on siemens phones, type *#06# -> Press Info, and you see your Version.. A question, have you cut TP ?? BR |
1 Attachment(s) no i didn't cut , only made this TP on pic |
Thanks Chabah but i've already used SST 5.32 but didn't work even not read info of my m65 and papua display boot not loaded |
hi sst 5.31 yes work well |
This tp maybe shorted for 0.5 ~ 1sec..On papuas, do not show something like : "Pause of 1s..", if its appears, in this moment release tp.. BR. |
if your phone up to v 25 you can unlock without any TP but if your phone with new vr like 36or43or50 you can go to this link and do evry thing in the link http://forum.gsmhosting.com/vbb/showthread.php?t=208706 |
my phone is V25 so i should do TP , but i think i should also modify the cable by (short pin 5,6,7 to pin 2 by Resistor of 10k) |
If have you noname cable, you may modify your cable shorting pin 2,5,7 to a 2 15k resistor.. But, with v25 you can unlock without TP, from SST, or DimaDebil(x65 unlocker) BR; |
You need only to solder these wo resistors to the cable if you want to exchange date with siemens data exchange SW! |
my problem solved by SST 5.31 , and if you face the problem of none reading info or stoped at step when SST shows starting service mode when you power on your mobile follow this steps: when you clik on unlock SST shows starting service mode, and then 1- umplug cable from mobile 2-power on and 3-plug it again but rapidly and then the phone turns off by itself and SST ask you again to power on your mobile and when you do it , your mobile will be unlocked ;) it's 100% works and without TP if your phone is V.25 |
Ive got a M65 with the following infos: Product: M6V P. date: 2005-06-21 sw-version: 25 baseline: dummy-bl Which prog do u prefer to unlock(And version), and do i need to use any TP? Ive got SST 5.32. Do i need to use any special cable or the simple serial service cable is good enough? Thanks for your help! |
Your serial cable is enough! And you can direct unlock it with cracked SST without TSP! |
Thanks! Which version do u prefer? 5.31 or 5.32? |
