11-26-2004, 11:19 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 42
Member: 91950 Status: Offline Thanks Meter: 0 | ME45 Troubles First of all it works great, the menu acessing is fast, smooth there are no network problems whatsoever. The thing that bugs me is that after I format the drive the drive info says : Size 348 Kb, Free 347 Kb. Why is that?? And Second I've been having problems flashing it with patches or even fullflash, the software just does'nt upload. I had luck with S45i_040315.exe (WinSwup) which finishes with no error, but then I can't activate the crc patches, and the s/me crc - so I cant turn the phone on! After I loaded the new software I was able to turn on the crc's (with SMEactivation tools), but I cant upload any of the other patches?? I don't know what the problem with my phone is and should I try to flash it again??? If some1 can answer these questions for me I'd be very thankful!! |
11-26-2004, 14:39 | #2 (permalink) | ||||
Freak Poster Join Date: Jun 2004
Member: 70990 Status: Offline Thanks Meter: 1 | Quote:
Next step: After applying S45i_040315 use S45iv04 Activator by ACiD Download: http://www.gsmdev.de/index.php?c=viewprojektinfo&id=13 Using this very good tool for patching CRC and others. If you've done this successful you can turn on mobile. (if you get message "Wrong Software", please "Unlock" phone by using SME45Tools for example). Quote:
For applying (many) other patches, please use V_klay: Download: http://www.vi-soft.com.ua/ Quote:
genetic1 | ||||
11-30-2004, 08:21 | #3 (permalink) |
Member: 91950 Status: Offline Thanks Meter: 0 | I have done everything you have described above, have been doing it from the start, but that is not the case here!!! I can't restore my original FUBU, so is there a way to format/erase the complete memory range, and then to upload the FUBU or smthing??? because I'm scared that if I just try to flash it again it might not work??? |
11-30-2004, 13:57 | #4 (permalink) |
Member: 70990 Status: Offline Thanks Meter: 1 | If you have your (working) orig. Fubu you haven't to be "scared"! One reason,that your upgrade doesn't work, could be your chipset...BA20 Chip is a little bit more difficult as CE20, C289 or C489 Chip. Use this link and download SME45Tools: http://gsmfree.vipserver.ru/Siemens/sme45_sme45i.htm There is also a manual, how to update SME45 to SME45i (but only in german!) In your case...select register "Write flash"..."Read from file" (here you must select your orig. Fubu)..."Write to flash" (short pression red button) - READY! Now your orig. Fubu will be restored. It works 100%. Please search forum, too. There are "hundreds" of posts about this topic... Example:http://forum.gsmhosting.com/vbb/show...ghlight=sme45i BTW: (Hope you use an non-original-datacable)!!! Have you charged your battery to max. before you made your fubu? So before restore your fubu, you have to charge your battery to max. again! BR genetic1 Last edited by genetic1; 11-30-2004 at 14:22. |
12-01-2004, 08:08 | #5 (permalink) |
Member: 91950 Status: Offline Thanks Meter: 0 | Thanx for all your help, I'll look into what you say and I should check about the cable, it is suposed to be a patched SL45 cable but I'm not sure And again thank you!!! |
me45 unloking | mcc | x1x to x45/x50 | 0 | 10-25-2001 17:41 |
searching for me45 upgrade 07 lg1 !! | Proggy | x1x to x45/x50 | 10 | 10-16-2001 22:30 |
Flash for ME45 | daro | x1x to x45/x50 | 5 | 10-09-2001 22:17 |
Experience new ME45 | Swen | x1x to x45/x50 | 1 | 09-20-2001 12:12 |
Soft for S/ME45 | Vasuk | x1x to x45/x50 | 1 | 09-20-2001 11:34 |
