Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 09-02-2004, 14:33   #31 (permalink)
Member: 76949
The new navigation is perfect! Just as I always wanted :-)
Besides of bug that rc-flitzer already reported I have found another. The midlet doesn't save settings after it's shutdown.
I have a small suggestion to increase the ergonomy. You could add a faster way to exit the midlet. It could be a double click on red button when the midlet is in the first screen to prevent accidentally exits. AnalizatorLogow by KF has this feature.
Old 09-02-2004, 15:09   #32 (permalink)
Member: 60520
You mean that's the actual number recorded? (+749785<2>238>:>2)??
Yes, that's the "number"... it's not really the number, it's not even a +74 - I'm living in Germany, so +49 is my national calling code. As I said, it's a name "W.Grabbe" stored instead of the number. Modern mobiles can interpret them as text (maybe a flag or something), but not Riza's patch, so I just get this weird code number. Since it is the only number of this kind I don't need to know the name...
Thank you for correcting the problem. I think in Germany there are numbers of up to 15 chars length. Or foreign numbers, could be one or two chars longer.
Old 09-02-2004, 16:22   #33 (permalink)
Member: 67838
Update
logNavigator v0.45SR1
Service release
BugFix: Corrected bug mentioned by rc-flitzer. Number can now be 20 chars long, so there shouldn't be a problem anymore.
Kind regards,
Andrei
Old 09-02-2004, 16:23   #34 (permalink)
Member: 67838
That's not a bug, it's not implemented at all. There will be a time however when it will save settings.
Andrei
Old 09-02-2004, 19:33   #35 (permalink)
MacKam's Avatar
Member: 30834
I've got some suggestions:
- So I think that Delivery Report it's only useless thing so we can add it only like option for check, not like now on the list. I mean add possibility to see that our SMS come using Icon Indicator in SMS->Sends So we will have few lines free.
- On detail screan add position indicator. Like on list screan.
| ### +1234455678 X/Y <------ This
| sent
| +1234455678
| Taday @ 11:18
Or add more icon indicator! Like in LogReader
| ### +1234455678 X/Y
| ICON INDICATOR <----- this
| +1234455678
| Taday @ 11:18
- Can you add furture like in AnalizatorLogów. I mean "Check name from AdressBook"?
- In "Control Panel" add possibitity to set "bild month start" e.g. form 8.IX.94 do 8.X.04. And on this data count "time".
PS: Andrei I'am impressed! It's so fast!
Oh.. and what do you think about this:
http://forum.gsmhosting.com/vbb/show...&postcount=110
Or request to Riza mayby he can add option in his CDR like "turn off Delivery Report LOG" because I think DR only make LOG file to more big.
Riza what do You think about write SMS to separete files too? On some phone I think SMS logs are too big, so java midlets can't handle with that big files.
regards for friends from simensinfo!
Old 09-02-2004, 20:09   #36 (permalink)
Member: 67838
Originally Posted by adancau
Other than bugfixes...
Ok, I lied. Since I see that people want badly some specific features, I will do them before the cost calculation.
Here's a new update.
UPDATE
logNavigator v0.46
Change Log
- Added SMS icons in SMS list, since I see that many people ask for this. Date has been reduced to just day (month has been taken out) to accomodate the icons. (There will be a new version featuring icons in the detailed view also.)
Have fun,
Andrei
Old 09-02-2004, 20:55   #37 (permalink)
Member: 65231
Esthetical suggestion regarding sms icons in lisst view - icons for received and sent sms should be more distinctive on first glance.
- Maybe only make one icon with transparent triangle (only black outline), that should make solid and noticable difference with not much effort, or,
- maybe use open envelope icon for received sms (as in Logreader), or,
- make receved sms icon have left-to-right pointed triangle (which takes up left half of icon) and half of envelope (which takes up right half of icon, so, it's arrow and half of envelope on icon), and for sent sms it could be half envelope on left side of icon and triangle on right half of icon (so that triangle shows away from envelope)...
Some people may have other ideas, but main thing is to make those two icons distinctive, even on first glance.
Icon for delivery report is great. Please don't change it
Great implementation of ideas in midlet! Thanks again!
Old 09-02-2004, 21:02   #38 (permalink)
Member: 42457
@vizionar:
It's no problem to make icons on your own. Open JAD with a packer, unpack it and set new icons, then pack it again and ready for start
Old 09-02-2004, 22:04   #39 (permalink)
Member: 65231
Heyyyy, I didn't know that! Thanks a lot! Now, I don't have to beg I'm a programmer myself
Thanks a lot for tip! It's a great tip.
Old 09-02-2004, 22:20   #40 (permalink)
Member: 67838
UPDATE
logNavigator v0.47
Change Log
- added counter in detailed view mode (same as in the top right corner of the entry lists)
- changed SMS icons
Sorry guys, I had to take the axe to the SMS icon PNGs (for those of you curious enough to look in the resources folder in the jar). SMS icons are now done in the code using primitives. They're pretty simple yet I'd say they're intuitive enough. Also cut the screen PNGs there to include only the buttons. The reason for all this is that all that stuff takes up lots of memory, and with the last release you couldn't safely open a 12KB log.
I'm afraid we will have to keep in mind that the more features we implement, the smaller the logs that it can read.
Doing all the above managed to restore functionality with file sizes of up to 15, 15.5KB.
So unless you really want to mod icons in v0.46, I would strongly recommend to update to v0.47. v0.46 doesn't manage with large log files.
Kind regards,
Andrei
Old 09-02-2004, 23:12   #41 (permalink)
Member: 65231
Wow, you sure are quick Icons are not as neccessary as ability to open bigger files, so thanks for new version, bu just out of curiosity, why was I unable to load midlet when I changed pictures in it? Name of pictures, or format, of course, I didn't change. Compressed files to bin.jar with following options:
Archiving type: JAR
Action: ADD
Compression: NONE
Method: STORE
Following error is displayed when I try to load midlet "One or more midlet classes not found:Application".
Old 09-03-2004, 05:51   #42 (permalink)
Member: 67838
No idea. Maybe you didn't include Application.class?
Old 09-03-2004, 08:52   #43 (permalink)
Member: 65231
I did include evrything, whole bin file, just changed pics in resources.
Anyway, in next version of midlet, when you incorporate some more option maybe you could also change arrows for incoming and sent sms to be down arrow (received) and up arrow (sent) instead of left and right arrrow, as it is now. Just a suggestion. I belive it's even more intuitive that way.
Old 09-03-2004, 08:55   #44 (permalink)
Member: 67838
Ok, known bug in v0.47:
In the entry lists today's calls are displayed with the date instead time. Will be corrected in a new release this evening.
Old 09-03-2004, 11:59   #45 (permalink)
Member: 42457
Is it possible, to change the GUI like LogReader? I mean if you view an entry that it looks like that one as in LogReader? I don't know how easy it is to change that but the looking now isn't as good
But anyway - great midlet
LogReader vs callLogReader cyperghost x1x to x45/x50 2 08-31-2004 22:39
Adding Java Midlets to a 3410? Zadj Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 06-22-2003 12:31
Midlet over datacable ??? treborr x1x to x45/x50 0 09-04-2002 08:28
midlet 6310i nzarka Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-30-2002 15:50
Midlets & 6310i nuggie Nokia Digital Core Technology 4 ( DCT-4 ) 4 07-22-2002 02:31
Page generated in 0.22053 seconds with 10 queries
