11-16-2004, 10:57 | #736 (permalink) | |
Junior Member Join Date: Sep 2004 Location: Russia Age: 46
Member: 84388 Status: Offline Thanks Meter: 0 | How can I customize MULTI-INDICATOR patch for M55v91/11? I'd like to delete temprature and network peak level. Quote:
11-17-2004, 13:16 | #737 (permalink) |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | ;Try this one but i have not M55 FW11/91to test!!!! ; M55V11/V91: MULTI-INDICATOR ; (C)ZH-Soft, ACiD (P)AlexSid, !Freeman!, lalo.lerry (I)KoTsK ; + BATTERY LEVEL (%) ; + VIBRA INDICATOR ; + PROFILE INDICATOR ; !!! Need patch: GFX KOTSK.VKP (attached) !!! 0DDAD6: DA2DB2D2 DA9F0009;fixed #pragma enable old_equal_ff ;7F0890: DA2DB2D2D7400900F2F1663AE103F6F1;These lines call NETWORK PEAK LEVEL ;7F08A0: 0EFEE6FF64005BFFF2FE0EFEF2FF0CFE ;7F08B0: E04CE0AD06FE190088F0DA2DB2D298F0 ;7F08C0: F6FF0EFEE0AF5BFFF2FE0EFEF2FF0CFE ;7F08D0: E08CE0AD06FE190088F0DA2DB2D298E0 ;7F08E0: E0CCE0AD06FE1900DA2DB2D2E00CE0AD ;7F08F0: E6FE2500DA2DB2D2FA9F0009 7F0900: DA2DB2D2D7401300F2F1EC27F6F10EFE 7F0910: E6FF64005BFFF2FE0EFEF2FF0CFEE6FC 7F0920: 4A00E6FD000006FE290088F0DA2DB2D2 7F0930: 98F0F6FF0EFEE0AF5BFFF2FE0EFEF2FF 7F0940: 0CFEE6FC5000E6FD000006FE290088F0 7F0950: DA2DB2D298F0F0EFE6FC5600E6FD0000 7F0960: 06FE2900DA2DB2D2FA9F200A ;7F0992: DA2DB2D2D7401100F2F11E2126F1;These lines call ENVIRONMENT TEMPERATURE ;7F09A0: AA0AF6F10EFEE6F164005B11F2FE0EFE ;7F09B0: F2FF0CFEE0ADE6FC500006FE190088F0 ;7F09C0: DA2DB2D298F0F6FF0EFEE0AF5BFFF2FE ;7F09D0: 0EFEF2FF0CFEE0ADE6FC540006FE1900 ;7F09E0: 88F0DA2DB2D2E6FC5800E0ADE6FE2300 ;7F09F0: DA2DB2D298E0E0ADE6FC5A0006FE1900 ;7F0A00: DA2DB2D2E6FE2400E0ADE6FC5E00DA2D ;7F0A10: B2D2FA9F200A 7F0A20: DA2DB2D20FF1D7400C00F6F100000D05;This line call vibra logo 7F0A30: 0EF1D7400C00F6F10000D7400C00F2FF 7F0A40: F63F9AFF03F0 7F0A46: E6FEAF01 ;#1AFh ---> FirstPictureNumber.VibraOn 7F0A4A: 0D02 7F0A4C: E6FEB001 ;#1B0h ---> FirstPictureNumber.VibraOff 7F0A50: E6FC3600 ;#036h ---> Xpos.Vibra 7F0A54: E0AD ;#00Ah ---> Ypos.Vibra 7F0A56: DA2DB2D2FA9F800A 7F0A80: DA2DB2D2DA8C0ECAC08CF0EC;This line call profile logo 7F0A8C: E6FC3300 ;#33h ---> FirstPictureNumber.Profile 7F0A90: 00EC 7F0A92: E6FC1600 ;#16h ---> Xpos.Profile 7F0A96: E0AD ;#0Ah ---> Ypos.Profile 7F0A98: DA2DB2D2DB00 #pragma disable old_equal_ff ;***************************** ;For M55V11, enable this line: 7F090A: EC EA ;***************************** |
11-18-2004, 11:12 | #738 (permalink) |
Junior Member Join Date: Nov 2004 Age: 42
Member: 91206 Status: Offline Thanks Meter: 0 | Problem with Provider Name -> Time, Environment Temperature patch ; Provider Name -> Time, Environment Temperature ; Format: 10:01 - 24,5'C ; M55 v11 ; 2004 by ACiD[mrp] ; GSM Development Crew www.gsm-dev.com ; Mobiletuning www.mobiletuning.de ; ; ; If you already applyed the ProviderTime Patch please ; undo this first. ; ; Sorry, there's no ° available so I've used an ' (This patch located on http://forum.gsmhosting.com/vbb/show...9&page=5&pp=15) I patched my M55 v11 with this patch and found the bug. After viewing animation *.gif, my phone turned off and didn't turn on later. I had to reflash my phone from backup. I found it strange and took another M55 v11. Situation repeated. What do You think about this? |
11-22-2004, 06:21 | #739 (permalink) |
Junior Member Join Date: Nov 2004 Age: 47
Member: 92978 Status: Offline Thanks Meter: 0 | Hi, Everyone! New member here. I want to try the 3.5Mb patch on my M55. I read that I should format my filesystem then restore factory settings. What happens if I don't do these and proceed directly to applying the patch? |
11-22-2004, 20:12 | #740 (permalink) |
Insane Poster Join Date: Jul 2004 Location: 0x00E00001 Age: 34
Member: 74486 Status: Offline Thanks Meter: 0 | Never heard of any such directions, to do before applying patch. The phone format's the disks itself anyway after you apply the patch, so I don't see the need in that. Though I may be wrong... Take care. |
11-24-2004, 04:42 | #742 (permalink) |
Member: 92978 Status: Offline Thanks Meter: 0 | is it ok to run WINSWUP even if the phone has patches or do I have to undo the patches first? btw, why do the patches have "#pragma enable old_equal_ff" and "#pragma disable old_equal_ff"? it is causing error in v_klay. is this ok? Last edited by Mike55; 11-24-2004 at 07:43. |
11-24-2004, 13:40 | #743 (permalink) | |
Member: 66180 Status: Offline Thanks Meter: 0 | Quote:
About "#pragma enable old_equal_ff" and "#pragma disable old_equal_ff" are useful for programmer to write patch without old data in each line but old data should be ffffffffffffffffffffffff otherwise V_Klay will tell you error in patching | |
12-02-2004, 13:34 | #746 (permalink) |
Junior Member Join Date: Nov 2004 Age: 39
Member: 94563 Status: Offline Thanks Meter: 0 | question! i've downloaded a patch that didn't really work on my m55... the patch is the one with 4,2 mb of memory ...the problem i have encountered is that when i wanted to apply the patch i got a message (something like "there is a modification on line 52-i think-and the old data should be same with the new one...") so, i couldn't do anything further. I WANNA KNOW WHAT I CAN DO TO REMEDIATE THIS PROBLEM! IF ANYONE HAS AN ANSWER PLS GIVE IT TO ME! |
12-04-2004, 14:45 | #748 (permalink) | |
Junior Member Join Date: Aug 2004 Location: Poland Age: 38
Member: 78197 Status: Offline Thanks Meter: 0 | Quote:
12-05-2004, 03:32 | #749 (permalink) | |
0DDAD6: DA2DB2D2 DA9F0009;fixed #pragma enable old_equal_ff ;7F0890: DA2DB2D2D7400900F2F1663AE103F6F1;These lines call NETWORK PEAK LEVEL ;7F08A0: 0EFEE6FF64005BFFF2FE0EFEF2FF0CFE ;7F08B0: E04CE0AD06FE190088F0DA2DB2D298F0 ;7F08C0: F6FF0EFEE0AF5BFFF2FE0EFEF2FF0CFE ;7F08D0: E08CE0AD06FE190088F0DA2DB2D298E0 ;7F08E0: E0CCE0AD06FE1900DA2DB2D2E00CE0AD ;7F08F0: E6FE2500DA2DB2D2FA9F0009 7F0900: DA2DB2D2D7401300F2F1EC27F6F10EFE;These lines call BATTERY LEVEL (%) 7F0910: E6FF64005BFFF2FE0EFEF2FF0CFEE6FC 7F0920: 4A00E6FD000006FE290088F0DA2DB2D2 7F0930: 98F0F6FF0EFEE0AF5BFFF2FE0EFEF2FF 7F0940: 0CFEE6FC5000E6FD000006FE290088F0 7F0950: DA2DB2D298F0F0EFE6FC5600E6FD0000 7F0960: 06FE2900DA2DB2D2FA9F9209 7F0992: DA2DB2D2D7401100F2F11E2126F1;These lines call ENVIRONMENT TEMPERATURE 7F09A0: AA0AF6F10EFEE6F164005B11F2FE0EFE 7F09B0: F2FF0CFEE0ADE6FC500006FE190088F0 7F09C0: DA2DB2D298F0F6FF0EFEE0AF5BFFF2FE 7F09D0: 0EFEF2FF0CFEE0ADE6FC540006FE1900 7F09E0: 88F0DA2DB2D2E6FC5800E0ADE6FE2300 7F09F0: DA2DB2D298E0E0ADE6FC5A0006FE1900 7F0A00: DA2DB2D2E6FE2400E0ADE6FC5E00DA2D 7F0A10: B2D2FA9F200A 7F0A20: DA2DB2D20FF1D7400C00F6F100000D05;This line call vibra logo 7F0A30: 0EF1D7400C00F6F10000D7400C00F2FF 7F0A40: F63F9AFF03F0 7F0A46: E6FEAF01 ;#1AFh ---> FirstPictureNumber.VibraOn 7F0A4A: 0D02 7F0A4C: E6FEB001 ;#1B0h ---> FirstPictureNumber.VibraOff 7F0A50: E6FC3200 ;#032h ---> Xpos.Vibra and if position is not center you can change digit between 28 to 34 7F0A54: E0AD ;#00Ah ---> Ypos.Vibra 7F0A56: DA2DB2D2FA9F800A 7F0A80: DA2DB2D2DA8C0ECAC08CF0EC;This line call profile logo 7F0A8C: E6FC3300 ;#33h ---> FirstPictureNumber.Profile 7F0A90: 00EC 7F0A92: E6FC0100 ;#001h ---> Xpos.Profile and change position instead network peak 7F0A96: E0AD ;#0Ah ---> Ypos.Profile 7F0A98: DA2DB2D2DB00 #pragma disable old_equal_ff ;***************************** ;For M55V11, enable this line: 7F090A: EC EA ;***************************** | |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
