12-13-2004, 05:26 | #781 (permalink) |
Junior Member Join Date: Nov 2004 Age: 47
Member: 92978 Status: Offline Thanks Meter: 0 | |
12-13-2004, 08:55 | #782 (permalink) | |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | Quote:
i think the way that may solve your problem is undo your patch 1 by 1,except 3.75Mb patch,to find which 1 caused that bug | |
12-15-2004, 04:05 | #783 (permalink) |
Member: 92978 Status: Offline Thanks Meter: 0 | hi. i reflashed my phone to v11. i did not install v91 anymore. installed the increase disk space patch then other patches. so far so good no problems. the only difference is i did not install the remove buttons from mainscreen patch. i noticed that when this patch is installed, function in the left softkey sometimes does not work or the phone becomes slow. |
12-17-2004, 06:45 | #787 (permalink) |
Member: 92978 Status: Offline Thanks Meter: 0 | the 3.62Mb patch for v91 works fine. is there a patch for changing the display of address book entries? instead of "lastname firstname" it will display as "firstname lastname" |
12-20-2004, 06:13 | #790 (permalink) |
Member: 66180 Status: Offline Thanks Meter: 0 | Could any one port this patch for v91? ;Replacement standard vibry M55v10 ;© Divisi0n_by_zer0 39A696: F401 FA00 ;Duration vibry in ms 39A69A: F401 FA00 ;Duration of a pause in ms |
12-20-2004, 19:39 | #792 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | Quote:
12-21-2004, 01:14 | #793 (permalink) | |
Thank you very much , and why this can used for all anuroj_007 M55 v91 | |
12-30-2004, 10:04 | #795 (permalink) |
Junior Member Join Date: Jul 2004 Age: 40
Member: 74817 Status: Offline Thanks Meter: 0 | a have a little problem with the camera wav recordin patch. on my phone I hava v11, I didn't find the version for v11 so I used the patch for v91. when I try to start the recording the phone shutdown. the camera must be attached to phone while I'm recording? |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
