Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 03-12-2005, 00:46   #166 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@Trek:
S45iv04 isn't a buggy version at all.. we all are using it since 3 years!
Maybe it's a buggy version for your phone, IMHO bugs arises between eeproms and fw.
Please make the last try:
Make a back up of FuBu
Make a back up of eeproms
Update phone with winsup v04i
Load into phone your eeproms backup
Apply patch necessary for have fw version i into S45
Enjoy it!
If any problem arises go back to your previuosly situation with FuBu backup.
Old 03-25-2005, 00:32   #167 (permalink)
misko903's Avatar
Member: 89407
@Trek:
if you are patching a phone without patch for disabling CRC (you may make one with Smelter, or download from patches thread), your phone make a long low beep and crashes. so try to disable CRC
@Lalo:
Whats the matter with you? we are waiting for your new patches as for a meal
Happy easter!
some easter eggs:
Old 03-27-2005, 14:33   #168 (permalink)
Member: 70080
Thanks Meter: 2
@RizaPN
Can you say about this function?
fillRectwStyle 0d6a216h
; mov [-r0], #style1
; mov [-r0], #style2
; mov r12, #X
; mov r13, #Y
; mov r14, #width
; mov r15, #height
Old 03-27-2005, 17:04   #169 (permalink)
Member: 70080
Thanks Meter: 2
@rizapn
Can you say format of SID?
Old 03-27-2005, 23:48   #170 (permalink)
Member: 9891
Thanks Meter: 2
SID (String ID) in the Extended String ID patch?
somewhere:
	mov r4, #pof(extStrTable)
	mov r5, #pag(extStrTable)
	calls setExtSIDTable ; 0e47ec0h
continue:
	rets
str_0e27:
	db 'This is your own string for ID 0E27',0
str_0e28:
	db 'And this for 0E28',0
str_0e29:
	db 'Same for this (0E29)',0
extStrTable:
	dw pof(str_0e27), pag(str_0e27)
	dw pof(str_0e28), pag(str_0e28)
	dw pof(str_0e29), pag(str_0e29)
;continue this table for all strings you need
Old 03-27-2005, 23:58   #171 (permalink)
Member: 70080
Thanks Meter: 2
tnx!
but as about unicode?
Old 03-28-2005, 00:46   #172 (permalink)
Member: 9891
Thanks Meter: 2
For character other than Latin support, you can put 9Bh (example for Russian characters) in the beginning of your string ...
Old 03-28-2005, 09:29   #173 (permalink)
Member: 70080
Thanks Meter: 2
tnx, it like siemens language editor, I understood
Old 03-30-2005, 21:54   #174 (permalink)
Member: 29316
2RizaPN: I found crack for Keil, whith this crack keil debug all 16Mb address range of C166 CPU if you need this crack write me to e-mail [email protected]
another question about runDelay funk, if i run my prog trought this function and not run stop timer funk at the and in my programm, my programm whill runing every delay (in example every 30 minut's) or i need to start timer again for run my programm ?
Old 03-30-2005, 23:52   #175 (permalink)
Member: 9891
Thanks Meter: 2
@DeadManS:
*) Thank's about Keil stuff ...
*) No, your program will not running every delay. It will stop if we exit from the main caller...
Old 03-31-2005, 15:46   #176 (permalink)
Member: 29316
if i whant run my program always in 30 minute's i need call runDelay at the and of my program always ?
Old 03-31-2005, 20:42   #177 (permalink)
Member: 94448
@DeadManS:
Your program will running every 30 minute's, but it will stop if you close the main caller (long red button, proc. doBack0A, etc.)
Old 03-31-2005, 23:46   #178 (permalink)
Member: 9891
Thanks Meter: 2
@DeadManS:
- Or, you can call your program from any known firmware background process, such as doMainScreen() which is used by us to modify the screen display, do hourly beep, etc-etc ...
Old 04-01-2005, 12:32   #179 (permalink)
Member: 94448
Hi everybody!
I have a question: how can i random some value?
Old 04-01-2005, 12:43   #180 (permalink)
Member: 70080
Thanks Meter: 2
typedef int huge p_rand(void);
p_rand* const far rand = (p_rand*)0xc7876e;
BB5 - Technical Discussion adihack Nokia Base Band 5 ( BB-5 ) 220 10-14-2011 05:31
x65 patching technical discussion Acidmrp x6x and x7x Flashpatching 42 10-10-2009 07:06
Iphone 3G Technical Discussion and SP Unlocking theory GraveSlayer iPhone 2 / iPhone 3G / iPhone 3GS 8 11-15-2008 06:04
Technical discussion sharp705sh celluniversal Sharp 0 05-17-2007 17:26
Technical discussion BB5 unlocking twisterfan Nokia Base Band 5 ( BB-5 ) 0 05-16-2007 19:36
Page generated in 0.27965 seconds with 10 queries
