04-09-2005, 11:47 | #182 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | SL45v56: About Incoming SMS Buffer: From CDR.asm (Call Detail Record) source: mov r8, #200h+'R' <- R(eceived) - put "received sms" flag in the register R8 mov r12, #315h - set R12 with value hexa 315 mov r5, #32h - and R5 with 32h R5:R12 is prepared to store the pointer to incoming SMS sender number (32h:0315h). extp r5, #1 - work in page values stored in register R5 (32h) movb rl4, 2F0h - get the byte value of RAM 32h:02F0h and store it in the RL4. 32h:02f0 for incoming SMS is storing the SMS type, including normal or delivery status SMS. I don't know about another values meaning ... andb rl4, #40h jmpr cc_Z, sdr_001 - make some test. if (RL4 and 40h==0) goto sdr_001 mov r8, #200h+'D' add r12, #1 - if the result of test is not zero (RL4 and 40h != 0), then set the flag with 'D' (Delivery status SMS), and change the incoming SMS sender number pointer to 32h:0316h ... Hope it is clear and usefull, rizapn Last edited by rizapn; 04-09-2005 at 12:02. |
04-09-2005, 22:00 | #184 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Poznan, Poland Age: 37
Member: 94448 Status: Offline Thanks Meter: 0 | Hi masters! Could you write me entrypoint to profile "without alarm"? <EDIT> And another two questions: In mainscreen after I push long red button it called to procedure shutting down. From whot adress it calls? And whot is the entrypoint to shut down phone? Last edited by sc0ty; 04-09-2005 at 22:29. |
04-10-2005, 06:39 | #185 (permalink) | |
Freak Poster Join Date: Jun 2004 Location: Russia, Zelenograd Age: 35
Member: 70080 Status: Offline Thanks Meter: 2 | Quote:
E5:252C DrawShutdownAnimation or see shutdown with confirm patch Last edited by Seklth; 04-10-2005 at 07:02. | |
04-10-2005, 08:36 | #186 (permalink) |
Member: 70080 Status: Offline Thanks Meter: 2 | if run emulator sl45 with parametr (mmiu35.exe /p) can see debug window ( http://patchslik.nm.ru/ClipBoard-1.gif ) Can i hook info from this window? |
04-11-2005, 00:38 | #189 (permalink) | |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | @Master Riza: Thank you for taking some time to answer my questions. I'll analyze your answers before posting any questions i may come into. here it is Quote:
BTW Thank you for your KVSIM patch. 2. RAM 000C:326C is for addressbook entries? low byte of this RAM is for POSTCODE? what does the high byte point to? Last edited by charlielao; 04-12-2005 at 01:07. Reason: Added some questions | |
04-12-2005, 10:11 | #190 (permalink) |
Junior Member Join Date: Apr 2005 Age: 53
Member: 134505 Status: Offline Thanks Meter: 0 | Hi all, I got hold of a lot different Siemens phones, and since I´m a experianced assembler programmer, I thought lets give it a go. So, yes im new here, and I might have posted this message in the wrong thread, DONT SHOOT ME, PLEASE I got all the tools Like V_Klay ffmod etc etc. and bought a copy of IDA (4.8). The only thing I cant seem to find is MMIU35.EXE, it seems interesting enought to have a look at....Can anyone point out a location? Next, I have a JTAG debugging system here with C166 support, the C35 has test points connected to the JTAG interface of the infineon chip, Although I have the scematics, I do not have the location of the testpoints, Anyone? if I cant get to the testpoint locations, I will take the infineon chip of the phone and use my multimeter to find them, seems mutch better solution since I have the gear. On the SL45 (yes I have the scematics and board layout) the JTAG interface of the infineon chip are NOT connected, I will take the chip off, end connect all 200 points with wires end connect the JTAG pins from the chip to my debugging system. Any one did this? I did find a way to flash SL42 to SL45 somewhere in the past, since I have only one SL45 and quite a lot of 42´s I would like the 42´s to become 45´s for debugging purposes can anyone point me to a howto, I do not seem to be able to find the information anymore Any other remarks or questions based on the above are very welcome... Jash |
04-12-2005, 11:22 | #191 (permalink) | ||
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | Quote:
04-12-2005, 17:39 | #192 (permalink) | |||
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | Quote:
04-13-2005, 08:44 | #193 (permalink) | |
Member: 134505 Status: Offline Thanks Meter: 0 | Quote:
I Have to find a way to thake the PMB6850 of the PCB and reconnect it with small wires or so to get the JTAG connections out leaving the rest of the phone intact. by doing so I can really look into the firmware. all information will be shared on this forum.... It might offer some help to you guys What is the stoy with the AT+CGSN debugging, although I did find the patch I do not find any description on how to use it, untill I have my JTAG system up and running I need this to start, anyone? One stupid thing thoud, one of my SL42 is upgraded to a SL45 now, one other keeps saying "Wrong software" any one with help on this ? | |
04-13-2005, 09:39 | #194 (permalink) | |
Freak Poster Join Date: Jun 2004 Location: Romania Age: 43
Member: 67838 Status: Offline Thanks Meter: 0 | Quote:
04-13-2005, 11:22 | #195 (permalink) | |
(but lets go no futher on this in this thread since it is off topic, I´m new here and do not want to be kicked out ) rgds Jash | |
BB5 - Technical Discussion | adihack | Nokia Base Band 5 ( BB-5 ) | 220 | 10-14-2011 05:31 |
x65 patching technical discussion | Acidmrp | x6x and x7x Flashpatching | 42 | 10-10-2009 07:06 |
Iphone 3G Technical Discussion and SP Unlocking theory | GraveSlayer | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 11-15-2008 06:04 |
Technical discussion sharp705sh | celluniversal | Sharp | 0 | 05-17-2007 17:26 |
Technical discussion BB5 unlocking | twisterfan | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 19:36 |
