Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 09-29-2005, 22:35   #241 (permalink)
Member: 94448
@patchers: Hi all!
I need e-point (or flag address) to proc witch checking sim card after start the phone. Could you help me?
Old 09-30-2005, 08:45   #242 (permalink)
trustkill's Avatar
Member: 27745
Maybe you can find it here:
;*** PWS. Phone Without SIM Card ***
;Firmware : SL45v56
;Author : DeadManS, rizapn
;Created : July 16, 2004 (original by DeadManS)
;Updated : July 17, 2004 (goto IDLE screen by rizapn)
;Fully (excluding all SIM related funcs) working phone without SIM Card
0x024C2A: E004 E014
0x44EEAC: DAE57C25 DAEEAC1C
Old 09-30-2005, 14:10   #243 (permalink)
misko903's Avatar
Member: 89407
@Lalo:
OK, i want to apologize you, i didn know it before... :/
one think. do you think it is possible to port miniGPS to S55? it is already for SL45i, x65 versions. i have source code, only some (2?) entry points are missing...
Old 09-30-2005, 20:51   #244 (permalink)
Member: 94448
@trustkill: I cant find this, it is something else
Old 10-01-2005, 15:25   #245 (permalink)
abomin's Avatar
Member: 48199
2 sc0ty
Probably it`s here:
csegCC:75E8       calls 0CCh, sub_CC651A
if r4=2 then SIM is not present.
(Info from chinese patch)
Old 10-01-2005, 16:43   #246 (permalink)
Member: 94448
Thx abomin it work great!
Old 10-18-2005, 13:43   #247 (permalink)
Member: 22528
I'm searching EntryPoint and parameters description for functions that converts 8bit messages to 7bit
(for example useful for decoding SMS messages)
Anyone knows it ?
Old 10-18-2005, 16:05   #248 (permalink)
Member: 60520
Write your own.
I'll have a look at this special problem today or tomorrow. In assembler the code should be easy.
Edit:
@Jester74: What exactly do you want to do? All text messages are either 7bit-GSM coded or it's unicode. I can write a routine that converts 8bit ASCII into 7bit GSM, but only the supported 135 chars from GSM charset. What input format do you have? What output format do you want?
Old 10-19-2005, 08:15   #249 (permalink)
Member: 22528
It looks like is that not sensitively I described my own problem.
I need the function which will convert of the 7 bit text recorded into 8 bit octets (unpack eigth bits to seven).
I wrote such function in C language and I compiled in Tasking C compiler.
Now only I am having to smooth the optained code and it will be OK, but in firmware must be such function, so what for to double it?
Old 10-19-2005, 11:13   #250 (permalink)
Member: 60520
??? What now? 7bit to 8bit or vice versa? You contradict yourself in both postings. But since you already have written the routine you need, it does no matter...
The question is: why are you searching this routine in FW if you have already written it yourself? What do you mean with "to double it"?? You could insert your routine in FW at a free space (I can give you locations) and make your own entrypoint, parameters etc.
Old 10-19-2005, 12:37   #251 (permalink)
Member: 22528
English is not my native language and from here the misunderstanding.
"converts 8bit messages to 7bit" this is almost the same what "convert of the 7 bit text recorded into 8 bit octets".
In both cases on the input we have 8 bit data and on the output may to be 7 bit. SMS messages are coded into such coding. For example:
4B FA 1B 44 0F B7 7F -> "Kto tam?"
This means exactly this what I wrote. The function of unpack eigth bits to seven must be in firmware (for SMS encoding for example).
We know what is the address of the screen memory, and in spite of this nobody writes her own functions to draw windows, dialogs, fonts, etc, only used are these with firmware.
Old 10-20-2005, 11:17   #252 (permalink)
Member: 60520
Hm, yes, the function should be somewhere in firmware. But I don't know where, I don't have commented source code from Siemens.
Old 10-24-2005, 09:12   #253 (permalink)
Member: 70080
Thanks Meter: 2
http://masique.v.kiev.ua/~semen/cross.htm
Tasking (полная версия на 2-х компактах вместе с крэком)
Old 10-24-2005, 14:21   #254 (permalink)
Member: 70080
Thanks Meter: 2
How to make call? Need for LogReader
Old 10-25-2005, 20:26   #255 (permalink)
Member: 94448
Hallo patchers! I need adress for song timer in mp3 player (full song time not play time). Could you help me?
BB5 - Technical Discussion adihack Nokia Base Band 5 ( BB-5 ) 220 10-14-2011 05:31
x65 patching technical discussion Acidmrp x6x and x7x Flashpatching 42 10-10-2009 07:06
Iphone 3G Technical Discussion and SP Unlocking theory GraveSlayer iPhone 2 / iPhone 3G / iPhone 3GS 8 11-15-2008 06:04
Technical discussion sharp705sh celluniversal Sharp 0 05-17-2007 17:26
Technical discussion BB5 unlocking twisterfan Nokia Base Band 5 ( BB-5 ) 0 05-16-2007 19:36
Page generated in 0.28222 seconds with 10 queries
