07-16-2004, 00:44 | #16 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Sorry, but I really have no other information about that functions. Maybe you can find something about that from chaos or mamaich site (I'm not sure). @DeadManS: Yes, as far as I know (from drawImgIdx routines), the PIT value is stored in that address. But, I never try to change the value to move PIT to the new address. Anyway, why do you need to move the PIT to the area if there is another way to extend it? If you move them, then you need another "big" free area for the new PIT. rizapn |
07-16-2004, 07:20 | #18 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @coollang: Long time no "see". Aha... that's my wish too. I did discuss some about T9 with mamaich, but we did not found something really clear about T9. I only cover very-very preliminary info about T9 structure. You can download it from my z-soft, http://groups.yahoo.com/group/z-soft...s/t9_trial.txt ... If you find some other thing, please share it with us ... |
07-17-2004, 15:16 | #21 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | @ Sekith: thanks @ Master RIZA: I've seen that in all you patches that have a request of confirmation you used to create a new MsgBox, but there isn't in SLIK fw a DisMsgBox? () function alread done (in S45i I found 3 - FA4D9C, FA4E18 and FA4E38)? And can you teach me well (even if I've yet partly understood) how to create a new msgbox (icon,text,sks,headers, sk answers jump...) Thanks Last edited by lalo.lerry; 07-17-2004 at 17:17. |
07-17-2004, 15:54 | #22 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Message Box and Dialogs Yes, SL45 also has some (many) display message box, such as : 0xE6F138, 0xE6EF0A, 0xE6F198, 0xE6EFE4, 0xD4E960, etc-etc. There are also some show Dialog routines, 0xE5DD76, 0xE5DE28, 0xE5ECD8, etc-etc. Mostly, I use the one in 0xE5DDCE (why? because, in my current knowledge, this is the most compact ones) ... and here is my 'generic' syntax : Code: #define showMsgIcon2 0E5DDCEh x_main: mov r12, #q(x_data) mov r13, #p(x_data) mov r14, #q(x_text) mov r15, r13 ; save 2 bytes jmps showMsgIcon2 x_handler: mov r4, r14 cmp r14, #23h ; if yes pressed jmpr cc_NZ, xh_rets jmps yes_function ; the function for Yes button xh_rets: rets x_data: dw 0,0,2 x_text: dw 4a0h, 0b5h, 7fffh ; pointer to text to displayed dw 0,0 dw o(x_handler), s(x_handler) dw 0,0,2c5ah,2e2h,4e26h,2 ; pointer to yes+no button definition x_text: dw string_ID, string_ID, string_ID, ... ,7fffh x_data: dw 0,0,2,x,y,7fffh, ... 2e2h,4e26h,2 I dunno the meaning of each word in the x_data, but some of them (time-to-wait, handler, and button-definition). I use a 'generic' format to display the generic (but different text) dialog. I saw that SME45iv04 has more 'powerfull' built-in displayYesNoDialog, such as : 0xFA4E18 (r12=style?,r13=text,r14=ofs(yes_handler),r15=seg( yes_handler)) ... rizapn Last edited by rizapn; 07-17-2004 at 16:18. |
07-17-2004, 17:13 | #23 (permalink) | |
Member: 50673 Status: Offline Thanks Meter: 2 | Thank you MASTER! Quote:
E.g.: DisplayMessageBoxD(? icon) { mov r12, flag ; #1=boxed, #2=unboxed mov r13, #textID mov r14, #segment offset(YESNOReturn) mov r15, #segment (YESNOReturn) call FA4E38 ; MsgBox ? icon with yes on left sk answer in r12: sk right o arrow right=no=0, sk left=yes=1, red button rets I think I'm going to use this if I'll adaptate you latest patches... May I ask you another thing? In these MsgBox? if mov r14 and r15 are setted to 0 where is return routine? I alway go mad to find them! | |
07-18-2004, 16:05 | #24 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | After some bugging in the SMS counter patch I discovered that the values for received and sent messages are stored in RAM right after values for currency calculator. I presume that the values will be stored in EEPROM together with curreny calc. values? Sometimes my SL crashes after sending an SMS (maybe from the modification with menu structures), so every change since last regular shutdown of the phone is lost. It's a pity that the SMS counts are only stored when shutting off the phone. Is it possible to write them directly into EEPROM, using the described eeprom routines? So the values will be stored immediately just like appointments. Or will this method be too time-critical? (I announce that values have to be also read from EEPROM not from RAM.) |
07-20-2004, 10:43 | #25 (permalink) |
Insane Poster Join Date: May 2002 Age: 40
Member: 12407 Status: Offline Thanks Meter: 0 | dear riza, there is a very interesting function in your rsb patch. D6A20A draws a rectangle of white pixels. now my question: is there also a function that does the same thing by drawing black pixels? this will make the drawing of the signal bars in my supernet patch much easier! thanks arsh0r |
07-20-2004, 13:26 | #26 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | SMS Counter Thank's. I never try (use EEPROM func in that SMS Counter patch), but I think it is possible. If the result is same (not directly write into the EEPROM), then we have to check more in the Appointment routines. About reading the value, I think it will be no different (read it from RAM or read it from EEPROM) because the SMS Counter function will be executed after all phone initialization (including copy most EEPROM content/pointer to the RAM). ClearRect and FillRect ... ClearRect is a sub-function of FillRect. FillRect() in SL45v56 is 0xC0E5D0, and here is the usage: Code: FillRect_test: mov r12, #color ; 0=white, 1=black mov [-r0], r12 mov r12, #X mov r13, #Y mov r14, #width mov r15, #height calls 0xC0E5D0 add r0, #2 rets sub_clearRect: mov r1, #0 mov [-r0], r1 calls 0xC0E5D0 add r0, #2 rets rizapn Last edited by rizapn; 07-20-2004 at 14:07. |
07-21-2004, 04:22 | #28 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | How i can load the mid file into a individual 1-3 song memory ? Patch idea: song name = phone number into in address book ringtone = individual3 before the play of ringtone when incomingcall we load a .mid file into a individual3 memory, and phone plays them |
07-21-2004, 12:50 | #29 (permalink) |
Member: 12407 Status: Offline Thanks Meter: 0 | thx riza, now it works perfectly! I also want to share my source with all of you: supernetv0.4beta: http://www.2chaos.de/supernet/supernet0.4.txt because i don't use mamaichs functions anymore, it can be easily ported to f.e. SME45 (but i only have sl45). we need more functions in the app menu, too many patches are allready selctable, theres nothing left. /edit: thx again riza, 48 patches ijn app menu will last for generations of patches... cya arsh0r Last edited by arsh0r; 07-22-2004 at 09:41. Reason: i want to |
07-26-2004, 10:52 | #30 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | I know how to do some shortcuts to functions in the app-menu. But only by changing some exiting patch code -> for example this: 0x18E388: 8B00 A904 ;string #8B -> #4A9 0x18E3BC: 8C00 A904 ;string #8B -> #4A9 0x18E4B8: 8B008B00 A904A904 ;same thing 0x3AE310: DAD70245 DAC7E0D3 ;call to patch How can I find the marked things ? The change of the language strings is easy to do, but I can´t reproduce the other things. The patch ist easy to do, too: Code: mov [-r0], r12 ; Register 12 sichern extp #0Eh, #01h mov r12, 03A42h ; r12 = 03BA42h jnb r12.1, notSelected ; springe, wenn bit 1 nicht gesetzt (=Funktion Nr. 2) bclr r12.1 jmpr cc_UC, clean notSelected: bset r12.1 clean: extp #0Eh, #01h mov 03A42h, r12 mov r12, [r0+] ; Register 12 zurück |
BB5 - Technical Discussion | adihack | Nokia Base Band 5 ( BB-5 ) | 220 | 10-14-2011 05:31 |
x65 patching technical discussion | Acidmrp | x6x and x7x Flashpatching | 42 | 10-10-2009 07:06 |
Iphone 3G Technical Discussion and SP Unlocking theory | GraveSlayer | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 11-15-2008 06:04 |
Technical discussion sharp705sh | celluniversal | Sharp | 0 | 05-17-2007 17:26 |
Technical discussion BB5 unlocking | twisterfan | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 19:36 |
