Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 05-15-2005, 00:04   #1081 (permalink)
Member: 60869
Lightbulb
New russian patch in ...patches thread!
Old 05-15-2005, 02:02   #1082 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
Wellcome and thank you to have posted them here!
(I had already seen them on Siemens-club.ru but wasn't able to understand them)
Old 05-15-2005, 12:02   #1083 (permalink)
Member: 60869
Thumbs up Ok :)
to Lalo:
Thanks you for "Vibra When Charge" always dreamed about this too.
check please my customization for your MBT patch.
thx in advance, Alter
Old 05-16-2005, 19:21   #1084 (permalink)
Member: 86191
Russian:
Пожалуйста, перевидите это на английский язык!
Как адаптировать телефон к 6-ти значным номерам, т.е. при наборе номера с клавиатуры и нажатии на вызов выводится Имя и номер - так вот они выводятся если номер совпадает с номером Телефонной книги с 7 цифрами, если номер содержит 6 цифр, то выводится только номер!!!
СПАСИБО!!!
English:
How to adapt phone to 6 to-place numbers, i.e. at a set of number from the keyboard and pressing a call the Name and number is deduced - and so they are deduced if number coincides with number of the Directory with 7 figures if number contains 6 figures number is deduced only!!!
Old 05-18-2005, 07:47   #1085 (permalink)
Member: 145781
Hi, to everyone Patchmakers, and not only him ;-) !!!
Greetings from Russia!
Some ideas of Patch for S/ME45i (Can create anyone like this...):
1) Small icon "1 hour" near by clock or accum - as you like (X,Y-coordinates ;-) ) if the items is active;
2) Quite well do scroll names from adress book, not fitting on screen when calling/receiving the abonent, like LongFileNames in Explorer (Much-needed...);
3) The Possibility under incoming calls to answer click right side button of the dictating machine: short clicking on button must play beforehand recorded voice and immediately terminate communication (or not terminate - patch settings need).
4) Light indication, beep sound then missed events...
Details:
If there is missed: Incoming call(s), SMS-message(s), Appointment(s) of organaiser - then phone, through nominated time, blink of light and (or) bleep of sound.
For more flexible adjusting work of patch quite well assign all this in 6 separate items at Applications menu, to example,
For reminder of missed event by means of blinking light:
- Calls_Light;
- SMS_Light;
- App_Light.
For reminder of missed event by means of bleep signal:
- Calls_Sound;
- SMS_Sound;
- App_Sound.
In patch configuration:
- a possibility to assign the gap of time between light flash;
- a possibility to assign the gap of time between bleeps;
- a possibility to assign the sequence of work light flash and bleep - synchronous/assynchronous (the offset initial of start first and the second);
- a possibility to assign time (between: since Hour:Min to Hour:Min), when will be an active light flash (does not eat charge of the battery daytime) (currently unless it is used patch "automatic change the profile")
- a possibility to assign time (between: since Hour:Min to Hour:Min), when will be an active bleep (does not disturb in the night) (currently unless it is used patch "automatic change the profile")
- a possibility to change the bleep on any one of "list sound".
Other:
- light indication (when item in menu Applications is active) must not operate if "Illumination is turn off" in menu of the Setup/Device/Display/Illumination;
- a sound reminder (when item in menu Applications is active) must not operate if "Ringer Setting is turn off" in menu Audio/Ringer Setting.
Something similar (about light indication) is present in standard functions of M55 and some other phones of the outside companies.
Quite well for S/ME45i to...
Dreams, dreams... :-)
I'm move a suggestion in russian forum, but there have left aside... :-(
That You will say on this...
Thank you in advance.
P.S. Sorry for my bad English %-)
Old 05-19-2005, 03:43   #1086 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@AlterGrey:
Sorry, I cannot test your MTB custimization.
Unfortunally, just today my notebook stop working, and I have all my files store there.
Probably I'll have to buy a new one, hoping to get my datas back from HD.
Old 05-20-2005, 13:03   #1087 (permalink)
Member: 91950
Probably a little error i copy/paste, or it might have something to do with temp. instead of time patch
;Little customization for MBT patch:
13A062: 4201 090A ; remove clock from Menu key on main screen <--DISABLED
;(& thx Ramil)
0587D2: 3502 090A ; show clock instead of "Menu" on call screen <--displays DOG on call screen
;Apply after MBT patch!
0587D2: 3502 4201 <--This works like a charm
Old 05-31-2005, 21:18   #1088 (permalink)
genetic1's Avatar
Member: 70990
@Lalo:
I have an idea relating HBP-patch...what about to add a (very) little icon (maybe only a point) beside clock (in idle), if HBP is on??? (like some digi-watches...)!!!
Originally Posted by lalo.lerry
@genetic:
good idea.
I'll post a new HBP version in some days
...are you still alive...?
What about your promise...?
Old 06-01-2005, 21:35   #1089 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@genetic:
eeeeeeehhhhh ... really sorry, still no time (and still setupping my new notebook)
Old 06-02-2005, 03:58   #1090 (permalink)
Member: 140865
Wink newbie asking...
is there any patch for S/ME45i to use voice recorded in dictating machine for ringtone? i have asked the Master Riza PN, and he said he never explored S/ME45i anymore... anybody know? (coz i'm just a user, not programmer.. )
Old 06-02-2005, 06:54   #1091 (permalink)
misko903's Avatar
Member: 89407
@tLun
oooh, my dream
Old 06-03-2005, 04:52   #1092 (permalink)
Member: 140865
Originally Posted by misko903
@tLun
oooh, my dream
so anybody could??? Master Riza said it was easy... but unfortunately, i'm not a programmer....
Old 06-03-2005, 09:19   #1093 (permalink)
KTL
Member: 40736
Everybody are busy so we mast wait for their free time...... i want this patch to
Old 06-06-2005, 10:55   #1094 (permalink)
Member: 91950
How to put 6th picture in *** FSA. Full screen SMS send Animation
"we can insert any 6 images (101x67) sequence into the SMS picture area
(id in hex are 007D - 0081)"
when there is only place for 5 pictures in sms hex area 007D - 0081 ?????
007D= 125
0081= 129
Old 06-07-2005, 07:59   #1095 (permalink)
Member: 140865
007D= 125
0081= 129
yeah... and i have a problem too... after aplying FSA patch, my GFX menu is broken... why? any solution?
S/Me45i-v04: Flash Patches patch_me x4x, x5x Flashpatching 329 05-30-2010 10:49
821sc flash patch cid3 dead after flash cetech Z3X-Team Products 26 07-17-2009 12:12
L760 flashing patched flash problem Steph NSPRO 4 12-05-2008 11:04
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Need flash patched with Spanish lang for Neptune ! Kilowat Mitsubishi 4 05-21-2002 07:24
Page generated in 0.22048 seconds with 10 queries
