05-16-2005, 19:21 | #1084 (permalink) |
Junior Member Join Date: Oct 2004 Age: 39
Member: 86191 Status: Offline Thanks Meter: 0 | Russian: Пожалуйста, перевидите это на английский язык! Как адаптировать телефон к 6-ти значным номерам, т.е. при наборе номера с клавиатуры и нажатии на вызов выводится Имя и номер - так вот они выводятся если номер совпадает с номером Телефонной книги с 7 цифрами, если номер содержит 6 цифр, то выводится только номер!!! СПАСИБО!!! English: How to adapt phone to 6 to-place numbers, i.e. at a set of number from the keyboard and pressing a call the Name and number is deduced - and so they are deduced if number coincides with number of the Directory with 7 figures if number contains 6 figures number is deduced only!!! |
05-18-2005, 07:47 | #1085 (permalink) |
Junior Member Join Date: May 2005 Age: 46
Member: 145781 Status: Offline Thanks Meter: 0 | Hi, to everyone Patchmakers, and not only him ;-) !!! Greetings from Russia! Some ideas of Patch for S/ME45i (Can create anyone like this...): 1) Small icon "1 hour" near by clock or accum - as you like (X,Y-coordinates ;-) ) if the items is active; 2) Quite well do scroll names from adress book, not fitting on screen when calling/receiving the abonent, like LongFileNames in Explorer (Much-needed...); 3) The Possibility under incoming calls to answer click right side button of the dictating machine: short clicking on button must play beforehand recorded voice and immediately terminate communication (or not terminate - patch settings need). 4) Light indication, beep sound then missed events... Details: -------- If there is missed: Incoming call(s), SMS-message(s), Appointment(s) of organaiser - then phone, through nominated time, blink of light and (or) bleep of sound. For more flexible adjusting work of patch quite well assign all this in 6 separate items at Applications menu, to example, For reminder of missed event by means of blinking light: - Calls_Light; - SMS_Light; - App_Light. For reminder of missed event by means of bleep signal: - Calls_Sound; - SMS_Sound; - App_Sound. In patch configuration: - a possibility to assign the gap of time between light flash; - a possibility to assign the gap of time between bleeps; - a possibility to assign the sequence of work light flash and bleep - synchronous/assynchronous (the offset initial of start first and the second); - a possibility to assign time (between: since Hour:Min to Hour:Min), when will be an active light flash (does not eat charge of the battery daytime) (currently unless it is used patch "automatic change the profile") - a possibility to assign time (between: since Hour:Min to Hour:Min), when will be an active bleep (does not disturb in the night) (currently unless it is used patch "automatic change the profile") - a possibility to change the bleep on any one of "list sound". Other: - light indication (when item in menu Applications is active) must not operate if "Illumination is turn off" in menu of the Setup/Device/Display/Illumination; - a sound reminder (when item in menu Applications is active) must not operate if "Ringer Setting is turn off" in menu Audio/Ringer Setting. Something similar (about light indication) is present in standard functions of M55 and some other phones of the outside companies. Quite well for S/ME45i to... Dreams, dreams... :-) I'm move a suggestion in russian forum, but there have left aside... :-( That You will say on this... Thank you in advance. P.S. Sorry for my bad English %-) |
05-19-2005, 03:43 | #1086 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | @AlterGrey: Sorry, I cannot test your MTB custimization. Unfortunally, just today my notebook stop working, and I have all my files store there. Probably I'll have to buy a new one, hoping to get my datas back from HD. |
05-20-2005, 13:03 | #1087 (permalink) |
Junior Member Join Date: Nov 2004 Age: 42
Member: 91950 Status: Offline Thanks Meter: 0 | Probably a little error i copy/paste, or it might have something to do with temp. instead of time patch ;Little customization for MBT patch: 13A062: 4201 090A ; remove clock from Menu key on main screen <--DISABLED ;(& thx Ramil) 0587D2: 3502 090A ; show clock instead of "Menu" on call screen <--displays DOG on call screen ;Apply after MBT patch! 0587D2: 3502 4201 <--This works like a charm |
05-31-2005, 21:18 | #1088 (permalink) | ||
Freak Poster Join Date: Jun 2004
Member: 70990 Status: Offline Thanks Meter: 1 | @Lalo: Quote:
What about your promise...? | ||
06-02-2005, 03:58 | #1090 (permalink) |
Junior Member Join Date: Apr 2005 Age: 44
Member: 140865 Status: Offline Thanks Meter: 0 | newbie asking... is there any patch for S/ME45i to use voice recorded in dictating machine for ringtone? i have asked the Master Riza PN, and he said he never explored S/ME45i anymore... anybody know? (coz i'm just a user, not programmer.. ) |
06-06-2005, 10:55 | #1094 (permalink) |
Member: 91950 Status: Offline Thanks Meter: 0 | How to put 6th picture in *** FSA. Full screen SMS send Animation "we can insert any 6 images (101x67) sequence into the SMS picture area (id in hex are 007D - 0081)" when there is only place for 5 pictures in sms hex area 007D - 0081 ????? 007D= 125 0081= 129 |
06-07-2005, 07:59 | #1095 (permalink) | |
Member: 140865 Status: Offline Thanks Meter: 0 | Quote:
S/Me45i-v04: Flash Patches | patch_me | x4x, x5x Flashpatching | 329 | 05-30-2010 10:49 |
821sc flash patch cid3 dead after flash | cetech | Z3X-Team Products | 26 | 07-17-2009 12:12 |
L760 flashing patched flash problem | Steph | NSPRO | 4 | 12-05-2008 11:04 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Need flash patched with Spanish lang for Neptune ! | Kilowat | Mitsubishi | 4 | 05-21-2002 07:24 |
