Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 03-18-2003, 11:18   #61 (permalink)
Member: 23262
Originally posted by juchasek
BTW: Has anybody tested this one:
Increased FlexMemory (393,51kb) after format is still increased (we don't have to patch (increase) memory again) (probably by Jaelenicu)
02BBF6: 00 02 -> 80 00
3A5526: 66 -> E6
3A5528: FF -> 0C
3A554E: D4 E0 0A 00 -> E6 FE 20 03
3A5771: 2C -> 1C
3A5796: D4 C0 02 00 -> E6 FC 20 03
3A58D9: 20 60 -> 00 5A
Is it working with no problems?
I don't have "00 02" at 0x02BBF6 in my s45i_v4. This offset is in the middle of strings like this one:
"....Browserdevice:reload%02XApply$(ServiceNumber_ wml)TextFilemainService menumore...."
I applied other changes, but now i have 381,51KB flash, not 393,51KB. Any ideas?
Old 03-19-2003, 18:10   #62 (permalink)
Member: 22716
Originally posted by Dentin
OK, thanks RizaPN. Do you know why my phone is always turning off?
Hi I have the same problem, but it is related somehow to reception level. In Some areas it turns off and for ex. when I am home it works fine.
Old 03-29-2003, 22:53   #63 (permalink)
ValeraVi's Avatar
Member: 24687
@RizaPN
Hello!
Is it posible to make a adjustment of brightness of backlight (illumination) on ME45, like in SL45 (Menu->Setup->Device->Display->Options on Illumination (by LeftSoftKey)->Up/Down for adjustment)?
Old 03-30-2003, 08:46   #64 (permalink)
Member: 15820
I don't thinks so, because now after I completly got mad about that turning of, I bring back my original ME45 v30 flash and after that, and that I done 20 days ago, it isn't turned of ONCE.
Old 03-30-2003, 13:40   #65 (permalink)
Member: 24439
ValeraVi when you make V_Klay for S/ME45i ??
Old 03-30-2003, 18:24   #66 (permalink)
ValeraVi's Avatar
Member: 24687
@Kunio
I will try, soon, to add support a S/ME45i in my V_KLay...
But you can use it now, also. Download by other flaser program a part of flash, that you want to patch, select in my program "Work with" "File with part of flash" and load this part of flash (do not forget to specify the correct address, from what you has downloaded the part of flash). After aplying the patch, upload this part of flash back to the phone with help of other flasher.
Old 03-30-2003, 19:13   #67 (permalink)
Member: 24439
Ok thx. I'll try!
Old 03-30-2003, 19:14   #68 (permalink)
Member: 24439
To RizaPN
when it would be more patches for S/ME45i v04???
Old 04-07-2003, 10:14   #69 (permalink)
Member: 25477
Originally posted by rizapn
New patches ...
2) Modify #[UpperRight] from "View CB" to "Explorer" shortcut :
0x5645E8 : AA 02 -> B2 08
0x5648A8 : DA F1 76 84 -> DA F5 3C E4
RizaPN
@ rizapn,
i'm a newbie here and i'm not a techy person so i have a hard time understanding some of the technical terms here. i upgraded my siemens 3618 v24 (me56 asian version) to me45 v30. i wanted to make a shorcut for EXPLORER but i'm not sure if the hexdecimal numbers you mentioned is the same for me45 v30. if this file patching applicable also to me45 v30? if so, what is the exact patching? thanks.
Old 04-10-2003, 11:42   #70 (permalink)
Member: 20967
Hi, this is my first patch /i hope that nobody do it before /
Use Explorer without sim card:
05A656 : C5 04 --> 59 05
I have original S45i with FW v.04
Old 04-10-2003, 13:06   #71 (permalink)
Member: 16423
This nice! Thanks!
Old 04-10-2003, 13:15   #72 (permalink)
Member: 26307
Thanks a lot
I hope it will be right, i'm going to test it...
Old 04-14-2003, 14:09   #73 (permalink)
Member: 20967
This patch ONLY show menu Java in Surf&Fun, but maybe this mean that FW is ready for Java!?:
05A6E4: 4405 --> 5905
Old 04-14-2003, 17:23   #74 (permalink)
GIROSAVO's Avatar
Member: 26549
you are big fishu !!! [][]
Old 04-16-2003, 11:41   #75 (permalink)
Member: 20967
i will be big when i activate java /i don`t know it is imposible/
S/Me45i-v04: Flash Patches patch_me x4x, x5x Flashpatching 329 05-30-2010 10:49
821sc flash patch cid3 dead after flash cetech Z3X-Team Products 26 07-17-2009 12:12
L760 flashing patched flash problem Steph NSPRO 4 12-05-2008 11:04
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Need flash patched with Spanish lang for Neptune ! Kilowat Mitsubishi 4 05-21-2002 07:24
Page generated in 0.26428 seconds with 10 queries
