12-13-2004, 21:37 | #856 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | Some patchers use it to make their patches (e.g. Acid). Others (e.g.Mamaich) use Tasking C166 complier, or other compliers... I don't use them, I (and the most ones) prefer to make them with Riza's SFE, or to work directly with opcodes. Just a metter of taste and habbit. |
12-14-2004, 18:33 | #857 (permalink) | |
Freak Poster Join Date: Jun 2004
Member: 70990 Status: Offline Thanks Meter: 1 | OPS. v1.1 @Lalo: Quote:
Could it be, that little bug was this => incomming flash SMS where not displayed in screensaver mode - only in idle? I've applied new version, but not tested yet - but I think it's 100% okay! BR genetic1 | |
12-14-2004, 18:53 | #858 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @genetic: quite right! the bug was that if a info string type 3 (beetwen 8 types, 3=Immediate Flash Message) arrived, it was displayed but only the first 15 characters, didn't scroll. Now is fixed. |
12-16-2004, 10:26 | #859 (permalink) |
Junior Member Join Date: Oct 2004 Age: 54
Member: 89010 Status: Offline Thanks Meter: 0 | ; LKM 1.0 Loadable Kernel Modules ; Firmware : S45iv4 ; Author: cotrinaf ; Created: 06.12.2004 ; Based in LPF by DeadManS ; With some ideas taken from lalo.lerry and RizaPN ; This patch will load a file in RAM and can run it ; First: Apply this patch ; Second: Create a silly patch and generate the code (.bin file) ; Alternativelly, use vkp2bin ; Third: Name that file as PPPPOOOO.bin , ; where PPPP is the page, OOOO is the offset ; Fourth: Copy PPPPOOOO.bin into FLEXmem with Data Exchange Software ; It must go to A:\ , not to A:\ Misc ; Five: On the phone, go to Menu->Surf&fun->Explorer->PPPPOOOO.bin ; and Options->Attributes->Select ; Six: Press key Dictaphone . This will load the loadable module ; Seven: Go to any menu, and press Dictaphone key to run the module ; example: use vkp2bin to convert this silly patch ; 0x000000: 88C088D088E088F08880E6FDAE00D740 ; 0x000010: 3E00A8ED5C2ED7403E00B8EDE028DACD ; 0x000020: 7EDC98F098E098D098C0DB00 ; and rename as 00400900.bin ; Then, start playing StackAttack. Press Dictaphone and your ; score will be multiplied by 2 , and a short beep will play. ; known bugs: -sometimes the module runs twice ; -once the module has been loaded, the file can not be deleted. Rename it. ; limitations:-there is no indication that the module has been loaded ; -only runs the last loaded module ; -files must be in the A:\ , not anywhere else ; -it will blindly write to the address, and fail if it is in ROM ; -modules must be smaller than 256 bytes ; -this version sends debug inforamtion to serial port ; -this version uses the same address as other patches ; -filename can be anything, as long as it ends with PPPPOOOO.bin ; -PPPPOOOO.bin will be loaded in PPPP:OOOO, that is, in ; memory PPPP*4000+OOOO%4000. For example, 00400900.bin will go to 100900h ; I plan to enhance it because I want to create many loadable patches. ; enjoy base 0A00000h #include C166.inc base 0A00000h org 0A7C6D0h ; some free area load_file: ; result r5=#20h .run #01h .bin #00h nothing mov [-r0], r15 mov [-r0], r14 mov [-r0], r13 mov [-r0], r12 mov [-r0], r7 mov [-r0], r6 mov [-r0], r4 mov r13, #012h ; segment for the filename mov r5, #20h ; how manz times search for \0 mov r14, #1E1Ch ; filename should start in 0012:1E1C at+cgsn:12,1E1C loop_letter: extp r13, #1 movb rl4, [r14+] cmpb rl4, #0h ; por fin: \0 jmpr cc_Z, si0 callr send_number sub r5,#1h ;not found yet. increase and continue searching jmpr cc_NZ, loop_letter jmpr cc_UC, sal si0: sub r14,#02h ; 2 bytes before \0 .might be .bin or .run extp r13, #1 movb rl4, [r14] callr send_number cmpb rl4, #'n' ; does not end with 'n' jmpr cc_NZ, sal mov r5, #1h ; start with 'i' sub r14, #01h ; previous char. Might be .bIn or .rUn extp r13, #1 movb rl4, [r14] callr send_number cmpb rl4, #'u' jmpr cc_NZ, got_iu mov r5,#20h ; flag that got_iu: sub r14, #0Ah ; 12345678.b ; filename start mov r12, #1E1Ch ; file name callr r13r14_2i ; get first 4 chars from name: 1234 mov r7, r3 callr r13r14_2i ; 4 next chars: 5678 mov r6, r3 ;copy file name from r13:r12 to r7:r6 mov r15, #0 mov [-r0], r5 mov [-r0], r7 mov [-r0], r6 ; need to copy the file name somewhere. Use the mem where the content will be stored mov r14, #0Ch ; copy 0C*2=24 chars loop_copy_ascii: extp r13, #1 mov r5,[r12+] extp r7, #1 mov [r6],r5 add r6, #2h sub r14, #1 jmpr cc_NZ, loop_copy_ascii mov r12, [r0+] ; quick way to retrieve r6 mov [-r0], r12 mov r13, r7 calls 0DA2C98h ; search file with name r13:r12 mov r6, [r0+] ; this seems to delete the first letter (in r13:r12) mov r7, [r0+] ; use this to know if the file has already been loaded mov r5, [r0+] cmp r4, #0FFFFh jmpr cc_Z, sal mov r12, r4 encontrado: mov r4,#'M' ; found callr send_number mov r4, r12 mov [-r0], r12 mov r14, r7 mov r13, r6 mov r15, #100h mov [-r0], r5 calls 0DA30F2h ; load file in r14:r13, maximal r5 bytes mov r12, [r0+] calls 0DA4AB4h mov r4,#'L' callr send_number ;load in 010081Ah the addres where it should jump mov r5, r7 shl r5, #0Eh or r6, r5 mov r5, r7 shr r5, #2 movb rh5, rl5 movb rl5, #0FAh ; jmps mov r4, r6 mov r3, #081Ah extp #40h,#1 mov [r3], r5 add r3, #02h extp #40h,#1 mov [r3], r4 mov r5, [r0+] ; exit flag sal: mov r4, [r0+] mov r6, [r0+] mov r7, [r0+] mov r12, [r0+] mov r13, [r0+] mov r14, [r0+] mov r15, [r0+] rets ; debug: send to port send_rl4: and r4, #000Fh add r4, #30h cmp r4, #3Ah jmpr cc_ULT, send_number add r4, #07h send_number: movb S0TBUF, rl4 bclr S0TIR ; send to port right_here: ;idle ;jnb S0TIR, right_here ; need to be connected to serial port nop ret ;translate ASCII to value get_r14: mov r4, #0 extp r13, #1 movb rl4, [r14+] cmpb rl4, #3Ah jmpr cc_ULT, number0 subb rl4, #07h number0: subb rl4, #30h and r4, #000Fh ret ;translate 4 ASCIIs to their value r13r14_2i: mov r15, #4 mov r3, #0 another_r15: shl r3, #4h callr get_r14 or r3, r4 callr send_rl4 sub r15, #1h jmpr cc_NZ, another_r15 ret ; ************************************* ; get key org 0CCB2CCh ; from CCB510 calls key_handler org 0A7C800h key_handler: mov [-r0], r5 mov r13, #0816h mov r5, r12 ; pressed key cmp r5, #000Bh ; is dictaphone? jmpr cc_NZ, exit_no_dict extp #40h,#1 mov r5, [r13] cmp r5, #2224h ; just run it? jmpr cc_Z, exit_no_dict calls load_file cmp r5, #20h ; is it an executable? jmpr cc_NZ, no_run calls 010081Ah no_run: mov r5, #2224h ; done: flag it jmpr cc_UC, almost_exit: exit_no_dict: mov r5, #2222h almost_exit: extp #40h,#1 mov [r13], r5 mov r5, [r0+] ; original code from 0CCB2CCh mov r13,#0 jmps 0CCB2ECh end 07C6D0: 88F088E088D088C0887088608840E6FD 07C6E0: 1200E6F52000E6FE1C1EDC4D998E4980 07C6F0: 2D04BB6928513DF90D5628E2DC4DA98E 07C700: BB6247F86E003D4FE01528E1DC4DA98E 07C710: BB5A47F875003D02E6F5200026FE0A00 07C720: E6FC1C1EBB62F073BB60F063E00F8850 07C730: 88708860E0CEDC4D985CDC47B8560862 07C740: 28E13DF998C088C0F0D7DADA982C9860 07C750: 9870985046F4FFFF2D26F0C4E6F44D00 07C760: BB32F04C88C0F0E7F0D6E6FF00018850 07C770: DADAF23098C0DADAB44AE6F44C00BB23 07C780: F0575CE57065F0577C25F1BAE7FAFA00 07C790: F046E6F31A08D7404000B8530832D740 07C7A0: 4000B843985098409860987098C098D0 07C7B0: 98E098F0DB0066F40F0006F4300046F4 07C7C0: 3A008D010847F7F8B0FE7EB69AB6CC00 07C7D0: CB00E004DC4D998E47F83A008D012987 07C7E0: 27F8300066F40F00CB00E04FE0035C43 07C7F0: BBF07034BBE028F13DFACB00 2CB2CC: DAA700C8 07C800: 8850E6FD1608F05C46F50B003D10D740 07C810: 4000A85D46F524222D0ADAA7D0C646F5 07C820: 20003D02DA101A08E6F524220D02E6F5 07C830: 2222D7404000B85D9850E00DFACCECB2 |
12-17-2004, 13:20 | #860 (permalink) | |
Junior Member Join Date: Aug 2004 Age: 51
Member: 76708 Status: Offline Thanks Meter: 0 | Quote:
You use functions _open and _read. To close file, use _close in the end. S45i__open EQU 00DA2C98h S45i__read EQU 00DA30F2h S45i__write EQU 00DA3642h S45i__lseek EQU 00DA3DACh S45i__close EQU 00DA4AB4h | |
12-17-2004, 15:35 | #861 (permalink) |
Member: 89010 Status: Offline Thanks Meter: 0 | That's exactly the information I was looking for ! Where did you get it from? I would need the parameters, although probably I can figure them myself. That might fix some bug in my code. Thanks |
12-17-2004, 16:48 | #862 (permalink) |
Member: 76708 Status: Offline Thanks Meter: 0 | One of the main "methods" of discovering theese functions is comparing the code with famous IDA Pro 4.30 base by mamaich for SL45. ( http://mamaich.fu ckru.net ) Some others are discovered by ntcn and other patchers. BTW, there are some useful functions in firmware: S45i_strcpy EQU 0FF40A0h ; like C strcpy S45i_SendComCharRL5 EQU 0CDE6EEh S45i_ByteRL5ToHexChar EQU 0CDE6FAh You may use it in your patch. About parameters of file I/O functions: they should be much like it's C analogues (look for standard C functions documentation), but ntcn and RizaPN said that there are some tricks with it. You'd better ask them about it. |
12-17-2004, 21:43 | #863 (permalink) |
Insane Poster Join Date: Feb 2003
Member: 22759 Status: Offline Thanks Meter: 0 | Problem (imho, nobody has solved this problem) that functions _open/_close/.. cannot be called from any place of firmware. It is possible to call only from 0DA8102 (S45i_FILE_SYSTEM_proc). But we can set any flag (write "1" to unused area of RAM) and install an additional patch which running from S45i_FILE_SYSTEM_proc and, if the flag ("1") is set, this patch call _open, etc.. how to call S45i_FILE_SYSTEM_proc manually ? 1) Call function for reading a file of the certain type (so does RizaPN) or 2) Use phone menu to perform work with files (I use this method in the CL patch) |
12-19-2004, 17:59 | #864 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Slovakia Age: 41
Member: 89407 Status: Offline Thanks Meter: 0 | patch bugs: 1. my phone dont send correct *.mid files through IrDA to other mobile phones and to PC - i dont know the name of patch, which makes this error 2. patch GPT. Just another GPRS toggle: when i have GPRS in favourites, phone falls. with honour for best S45i patch creators Lalo, ntcn, Redkin, and others Antoine [KNet] |
12-19-2004, 23:52 | #865 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | 2. GPT. Apply this fix patch for correct working in favourites: 5D456: 6A 54 Thanks for compliments Bye Lalo Last edited by lalo.lerry; 12-20-2004 at 05:36. |
12-20-2004, 05:35 | #866 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @Redkin: I've was wondering why some patches I was working had strange behaviours, and finally found out: we are using the same RAM location to store patch state. Your SSSS patch use RAM address 113800 and following, the same as my at least 5 patch already pubblished. Morover, I'm developing 3 patch that uses that RAM area. Not a big problem, but I or you have to move patches to another RAM address, and we have to decide a personal RAM area. WBR Lalo |
12-20-2004, 10:44 | #867 (permalink) |
Member: 89010 Status: Offline Thanks Meter: 0 | @ntcn: Well, in my patch I open a file in the press key handler, not coming from S45i_FILE_SYSTEM_proc. Why does it work? Maybe I am already within S45i_FILE_SYSTEM_proc ? I ask because I am having a strange problem: I created a patch (screenshot) that open-write-close a file. It works when I call it from a menu. But it fails when I load it with LKM. Seems that it doesn't like to be called from an interrupt handler. I will use your technique to flag a pending operation, and call from 0DA8102 . Thanks for the advise. @redkin : any alternative link for the SL45 base? the web http://mamaich.fu ckru.net is forbidden by my firewall :-( Thanks to all. |
12-20-2004, 21:41 | #868 (permalink) | |
Member: 70990 Status: Offline Thanks Meter: 1 | @Lalo: Quote:
Do you suggest, to undo SSSS and AL&DC for first time, untill "problems" are fixed??? I don't like strange behaviours and unpleasant surprises!!! I am interested in your opinion. BR genetic1 | |
12-20-2004, 22:08 | #869 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | No, don't worry. You don't have to undo any of my released patches, even if some of them use the same Ram location of SSSS. SSSS patch use to show item selected in its menu a state buffer in RAM address 113804 and following 50w This buffer is used only if you enter the new SSSS menu. Secondly, my released patches seem not to be affected even if you have entered SSSS menu, because use only a bit, bit 0, as state flag. Problem arised with 3 patch I'm working, Read SMS while keylock v0.7, Improuved Blinking when Ringing and Missed Events String in idle/screensaver. I can use another RAM location, there is a lot of normally unused space, but I want to avoid in the future such a not easy to find problem, so we have to decide a "standard". In the same way, I use for my patch routines a specific fw area and not other, and others patchers let this area free... Last edited by lalo.lerry; 12-20-2004 at 22:59. |
12-20-2004, 22:44 | #870 (permalink) |
Member: 70990 Status: Offline Thanks Meter: 1 | ...okay - I think I got it. It was only a question - thanks for detailed answer! So I'll wish you, that redkin and yourself, will find your own "standards" in RAM area. Next I want to wish you already yet a MARRY CHRISTMAS AND A HAPPY NEW YEAR!!! Thanks for all support and creating patch(es) during 2nd half of the year... so here is my patch... TYL. THANK YOU LALO! That's it... genetic1 |
S/Me45i-v04: Flash Patches | patch_me | x4x, x5x Flashpatching | 329 | 05-30-2010 10:49 |
821sc flash patch cid3 dead after flash | cetech | Z3X-Team Products | 26 | 07-17-2009 12:12 |
L760 flashing patched flash problem | Steph | NSPRO | 4 | 12-05-2008 11:04 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Need flash patched with Spanish lang for Neptune ! | Kilowat | Mitsubishi | 4 | 05-21-2002 07:24 |
