Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 02-09-2007, 11:50   #781 (permalink)
Member: 264139
Smile n70 connection error
brother.I HAVE A N70.some times signal low and connection error.please give me a solution. [email protected]
Old 02-10-2007, 05:27   #782 (permalink)
Member: 64823
Thanks Meter: 439
go to the network setting change the mode to gsm only not DUAL mode!!
Old 02-10-2007, 11:00   #783 (permalink)
Member: 297323
Thanks Meter: 2
i have a 7710 which only once fell,
after takin the fall the phone started to hang at the Boot ( nokia hands logo ).
later i gave it in for service at nokia Service centre, they had flashed the phone, but after the flash the phone suddenly has no network. even after inserting a valid sim card.
the Nokia guys kept it for 3 months, and returened it as sayin its unrepairable.
am in India, Andhra Pradesh, Hyderabad.
Well according to my Knowledge the ppl up In nokia here r not even qualified to format a phone as they dont respond to any technical complaints.
Ive tried Flashin the Phone using Nokia Software Updater But the Model is not supported.
Flashing using Box or other stuff isnt available here yet.
ive tried Formatting the phone by *7370# but still no luck.
" The Phone shows no network" and " does not charge
when plugged in it show's " Not Charging"
ive tried changing the battery's but no luck.
Other Functions r workin " camera, music player ...etc
it does not hang now.
Plz help cus its turned into a Mp3 Player rather than a phone, and even the battery dont charge.
Old 02-12-2007, 06:59   #784 (permalink)
Member: 264139
n70 network problem
thanks for the reply brother.I have change gsm mode.but problem is same.when I calling display show "connection error" please give me a solution.
[email protected]
Old 02-13-2007, 05:12   #785 (permalink)
Member: 64823
Thanks Meter: 439
[email protected]
Now what i can tell you is to:
Full flash your phone,
Write good pm
FULL factory setting(UI)
if not ok Surely Hardware problem!!
Old 02-13-2007, 12:54   #786 (permalink)
Member: 264139
Talking n70 software
hi good friend..if u have good pm file please give me.
thanks you
[email protected]
Old 02-26-2007, 14:57   #787 (permalink)
Member: 421966
Thanks Meter: 4
nokia 3210 it allways so No Network Covrage,i heated RF section,whole bord.Which IC is realeated to network ,name started with H....,i forgot the name & location.and also flash with new flash,but no network at all .
plz help
Old 02-26-2007, 14:59   #788 (permalink)
Member: 421966
Thanks Meter: 4
nokia 3210 it allways so No Network Covrage,i heated RF section,whole bord. i forgot the location of HAGAR.and also flash with new flash,but no network at all .
plz help
Old 02-27-2007, 07:26   #789 (permalink)
.::Munazzam::.'s Avatar
Member: 251247
Sonork: 1001670304
Thanks Meter: 192
nokia 6510 no signal i changed pa antina switch but power on signal present light off sinal gone
Old 02-27-2007, 08:40   #790 (permalink)
Member: 24122
Thanks Meter: 4
plz help
Sir, you can't find the hagar on that unit. Just try to heat all the SAW filters...
Old 02-27-2007, 08:44   #791 (permalink)
Member: 380018
when the phon on after few secend the signal cutting what do u thing abut this problem?
Old 02-27-2007, 08:52   #792 (permalink)
Member: 380018
can u description abut phonix
Old 03-01-2007, 13:44   #793 (permalink)
Member: 376092
i hv got nokia 6030 b n 6061 from US tmobile those imei starting with 01.......... , to work those are not getting network, i was told to change imei to get network .
is it possible to change imei ?
- praveen
Old 03-22-2007, 15:43   #794 (permalink)
Member: 260312
any solution for no network found in bb5 models?
Old 03-22-2007, 15:45   #795 (permalink)
Member: 260312
i need the patch files of available models.can any one pls help me?
1220 NO signal solutions mrfixit Various CDMA/TDMA Cell Phones 2 03-16-2017 04:26
Nokia 1600 no signal solution required azam_gsm1 Nokia Hardware & Hardware Repair 9 02-23-2009 11:03
3100 No signal solution irfaN_vu Nokia Hardware & Hardware Repair 31 05-22-2008 03:54
For new beginners. here Nokia code's pazeth™ Nokia Hardware & Hardware Repair 0 06-26-2005 15:20
lg 8110 no signal solution ihsanali LG 5 03-03-2005 11:51
Page generated in 0.22311 seconds with 10 queries
