Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 03-14-2007, 03:20   #3331 (permalink)
shakeelajmal's Avatar
Member: 51639
Thanks Meter: 76
i have 1112 and 2310 both are in handsfree mode any hint to solve this problem..?
Old 03-14-2007, 06:41   #3332 (permalink)
Member: 467554
any n73 disassemble guide??? i found one in here but doesnt work....any1 link me?
Old 03-14-2007, 09:24   #3333 (permalink)
Member: 427479
Thanks Meter: 2
Originally Posted by pikatchuss View Post
helo snoopcell
last year i have the same problem with my nokia
and it was only disconnected circuit from the speaker
if you can open it and clean the circuit maybe it resolvethe problem
best regards
Already clean the board and heat flow it but still the same problem
Old 03-14-2007, 10:37   #3334 (permalink)
wiliam's Avatar
Member: 241831
Thanks Meter: 18
nokia 1600 keypad only 123456 is working any solution
Old 03-14-2007, 11:54   #3335 (permalink)
Member: 422920
Thanks Meter: 16
hay , i have 6630 it dosen't read the sim card and it switsh on directly in offligne mode, thanks for help as soon
Old 03-14-2007, 20:47   #3336 (permalink)
.:==di@bila==:.'s Avatar
Member: 254137
Sonork: 1592525
Thanks Meter: 275
6230 Insert Sim Card when u put it... strange for me and need solution!
Old 03-15-2007, 00:30   #3337 (permalink)
Member: 181489
siemens sx1-starts only boot screen,cant connect via usb,any solution?
don know the flash id,only have the IMEI
Old 03-15-2007, 06:37   #3338 (permalink)
Member: 369214
k310i battery backup
hi I am Vicky from surat.
Please help me.
There is Charging problem in my k310i.
battery discharge in just one call.
Can u send me the diagram of k310i
Old 03-15-2007, 06:43   #3339 (permalink)
Member: 431154
n 70
a new n70 mobile set .everything ok but no charging i do hearwar but no solve i have anathar idya help me
Old 03-15-2007, 06:46   #3340 (permalink)
Member: 369214
hi Will u help me?
There is charging problem in my sony ericsson k310i.
battery discharge in just one incoming call
Please send me the digram of k310i
thank u
Old 03-15-2007, 07:11   #3341 (permalink)
Member: 82711
Thanks Meter: 30
n70 on problem
i have a nokia n70 its working ok but when i remove battery it goes dead but after two or three tries rome and insert batter it goes on and ok plz help me what;s wrong with this set
Old 03-15-2007, 07:26   #3342 (permalink)
Member: 468219
Re: Motorola L7 - USB pin bent. Phone won't take a charge.
Hi, I tried wading through much of the site. I have a motorola L7 that has a bent pin inside the USB housing. At least that's the reason I think I cannot charge the phone. I can visually see the pin pushed way back while the other pins are resting snugly on the bottom grooves.
Is there a schematic somewhere that goes though how to open the phones USB housing? I need to straighten the pin and put it back in its housing, but don't want to take the risk of breaking the pin off while working from the outside.
Thanks
- SY
Old 03-15-2007, 10:20   #3343 (permalink)
Member: 372160
Thanks Meter: 11
where the Freak Posters for solation
Old 03-15-2007, 15:38   #3344 (permalink)
Member: 455290
Hi, i have some problesm micraphone is not working if you help me i will be happy
Old 03-15-2007, 15:40   #3345 (permalink)
Member: 455290
Hi, i have some problesm micraphone is not working if you help me i will be happy nokia 2610
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.27375 seconds with 11 queries
