Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
03-14-2007, 09:24 | #3333 (permalink) | |
Junior Member Join Date: Jan 2007
Member: 427479 Status: Offline Thanks Meter: 2 | Quote:
Already clean the board and heat flow it but still the same problem | |
03-15-2007, 06:37 | #3338 (permalink) |
Junior Member Join Date: Oct 2006 Location: SURAT
Member: 369214 Status: Offline Thanks Meter: 0 | k310i battery backup hi I am Vicky from surat. Please help me. There is Charging problem in my k310i. battery discharge in just one call. Can u send me the diagram of k310i Last edited by vikas_vrm0; 03-15-2007 at 06:47. |
03-15-2007, 06:46 | #3340 (permalink) |
Member: 369214 Status: Offline Thanks Meter: 0 | hi Will u help me? There is charging problem in my sony ericsson k310i. battery discharge in just one incoming call Please send me the digram of k310i thank u |
03-15-2007, 07:11 | #3341 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 43
Member: 82711 Status: Offline Thanks Meter: 30 | n70 on problem i have a nokia n70 its working ok but when i remove battery it goes dead but after two or three tries rome and insert batter it goes on and ok plz help me what;s wrong with this set |
03-15-2007, 07:26 | #3342 (permalink) |
Junior Member Join Date: Mar 2007
Member: 468219 Status: Offline Thanks Meter: 0 | Re: Motorola L7 - USB pin bent. Phone won't take a charge. Hi, I tried wading through much of the site. I have a motorola L7 that has a bent pin inside the USB housing. At least that's the reason I think I cannot charge the phone. I can visually see the pin pushed way back while the other pins are resting snugly on the bottom grooves. Is there a schematic somewhere that goes though how to open the phones USB housing? I need to straighten the pin and put it back in its housing, but don't want to take the risk of breaking the pin off while working from the outside. Thanks - SY |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
