Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 02-21-2009, 01:22   #1 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
[F480] installing new widgets, deleting unnecessary files
hello,
this time is for playing with f480 heavily
we cannot still modify two the most important files of the firmware [.bin and .rc1]
yet from some time there is a way to modify .ffs file
what can we do through that?
- delete unnecessary images, wallpapers or tones
- delete/remove locked games
- add games without necessity of uploading them later
- install new widgets offline
we need:
- winimage program http://ourworld.compuserve.com/homepages/G...nt/download.htm
- ffs file from the firmware we want to modify
- widgets or widget pack eg. http://www.mediafire.com/?jomb2wzwmmk
winimage itself is pretty easy in handling so I'll only describe briefly a way how to add widgets to the desired FW
1. run winimage
2. go to SystemFS/MediaSet and drag the unpacked widget pack http://www.mediafire.com/?jomb2wzwmmk
3. save file
4. download such modified ffs to your mobile using fastmultiloader
visual instruction:
attention!
after loading modified .ffs file there is very high probability that the telephone will go through standard format procedure
same as while loading new firmware so remember to backup anything you need
remeber that everything you do you do at your own risk and neither I nor anyone form this forum takes no responsibility for any damage you may cause by using these procedures!
n'joy
regards,
stn
Old 02-21-2009, 14:42   #2 (permalink)
Member: 958086
Thanks to me for finding it on a german forum!
You can remove the images no problems..but the stupid screen savre still displays the same pictures...ARGH
not tried to do a widget with it yet :-)
Old 02-21-2009, 15:48   #3 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
as a matter of fact, I knew about winimage a bit earlier, it started on a russian forums, my friend mentioned it to me,
when it comes to images as I wrote, not all of them are in ffs, some are in rc1
I'm especially curious about widgets, I don't have this phone myself so I couldn't check it, in the package you have 27 widgets
regards
Old 02-21-2009, 16:29   #4 (permalink)
Member: 977691
Hold up... i didnt get it.
how to put new Widgets on my f480?
i downloaded winimage , and i dont know how to connect to my phone with it...
HELP
Old 02-21-2009, 17:21   #5 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
HELP
I think I have clearly mentioned the way you do this..
so it's only possible when you modify one of the firmware files and then upload them to your phone
and no, you can't download it from phone, you have to uplaod a totally new firmware on your phone.. read about in the other guides that are here in this section of gsmhosting forum
and don't ask here how to do it, it's really all written
patient and carefull reading is the best solution to all of the problems..
Old 02-21-2009, 18:09   #6 (permalink)
Member: 977691
ok. i got it....
just 2 more thing- i can put more widgets without change the firmware? and i can switch back to my normal firmware after changing to another one?
Old 02-24-2009, 16:52   #7 (permalink)
Member: 951015
Thanks Meter: 3
It's a bit more complicated than that. Here's how to actually do it.
1. Open WinImage, and click on Open Folder- icon. Browse to the firmware folder you want to modify and open the FFS file. (Note that WinImage is searching for .bin- files by default, so change that to "all files".)
2. Go to SystemFS -> Mediaset -> Widget
3. Drag the widgets you want to add to this folder.
4. Save.
5. Go to SystemFS -> User -> WidgetDefault.ini
6. Open WidgetDefault.ini
7. Either change the amount of widgets in the text file (.ini) or
change the titles of default widgets to correspond the ones you just
dragged to Widget-folder.
8. Save the text file you just modified to Desktop as "WidgetDefault.ini" and drag it to the SystemFS/User-folder, select YES to overwrite the old file.
9. Save.
10. Do a firmware flash with the FFS.
Should work
Old 02-24-2009, 17:29   #8 (permalink)
Member: 951015
Thanks Meter: 3
ok. i got it....
1. No, you cannot.
2. Yes, you can change between firmwares as much as you want. Not that there's much difference between them. Some ridiculous menu colors and font types and that's it. I really regret ever getting this phone. It's miles behind Nokia.
Old 02-25-2009, 21:57   #9 (permalink)
Member: 981068
Where can I download more widgets to flash them myself?
Im using google -> opera widgets, but haven't tried them yet, installing now.
Old 02-26-2009, 05:08   #10 (permalink)
Member: 981219
Cant get it to work.. When i load the FFS file into multiloader it says it cant read it?
Old 02-26-2009, 08:19   #11 (permalink)
Member: 951015
Thanks Meter: 3
The FFS file can't be any larger than it originally was. In the newest firmware 29,9mb. Delete stuff like music or wallpapers using WinImage., in Media folder of FFS
The Following User Says Thank You to idkhannes For This Useful Post:
Old 02-26-2009, 11:35   #12 (permalink)
Member: 981219
Great.. Thanks! (20chars20chars)
Old 02-26-2009, 12:28   #13 (permalink)
Member: 951015
Thanks Meter: 3
NP at all ....................
Old 02-26-2009, 13:10   #14 (permalink)
Member: 981219
One more thing You refer to SystemFS -> User -> WidgetDefault.ini.. I cant find that in F48HCAHK2 or F48FXEIA3 for that matter.. Is it only a specific firmware you can add these widgets to?
Old 02-26-2009, 13:40   #15 (permalink)
Member: 951015
Thanks Meter: 3
Yes, it's only for the newest firmware, unfortunately.
Software for Removing unnecessary files d_t_e Nokia Multimedia 2 04-22-2009 08:09
How to install new version 5.0.5 with AVG antivirus installed! The Dog NSPRO 4 01-23-2009 02:11
Nec 343i delete locked files Jimbolino NEC 0 04-07-2006 02:16
Delete sys files? Burtie Sony Ericsson 2 10-08-2005 23:30
7250i cable scheme, new soft, delete old soft andyms2003 Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-02-2004 14:52
Page generated in 0.24283 seconds with 9 queries
