Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 03-30-2009, 05:39   #1 (permalink)
Member: 165236
Samung U700b Power Button does not work after flashing
After flashing with Nspro and rebooting, the U700b does not turn OFF. I tried it both with the slide closed and opened. It was switching on/off when I got it first, however. (The battery has a full charge).
I flashed it with 2 other firmwares and it remains doing the same. The last time I flashed it with Sim card (Digicel) inserted and it reboot normal and found the network and everything, however, it would not turn OFF, and when I remove and reinsert the battery, it would not turn ON. I tried pressing the POWER button on top for approximately 10-15 sec.
Any help about this issue?
Regards
Pj
Old 03-30-2009, 05:59   #2 (permalink)
Member: 592636
Thanks Meter: 674
do u sure your problem is software ?
chech hardware issu
Old 03-30-2009, 14:18   #3 (permalink)
Member: 165236
Power button used to work when customer brought it in....I only flashed it to add some languages in phone. Really strange.....
pls anyone had a similar experience?
Old 03-30-2009, 16:50   #4 (permalink)
Member: 257142
Thanks Meter: 59
change firmwar and test
Old 05-23-2009, 00:53   #5 (permalink)
Member: 1030339
Hi Paul
Did you manage to find the right firmware? I have a similar problem and it would be a big help if you found out what went wrong.
Similarly, if I find a solution, I'll post it here in case you still need it.
All the best.
2300 FM Radio does not work after flash????? chwaseem Nokia Digital Core Technology 4 ( DCT-4 ) 7 01-29-2010 18:24
W600 power button does not work.... luisfer99 Sony Ericsson Hardware Repair 0 04-25-2007 04:17
2300 FM radia does not work after flash???? chwaseem UFS2 + UFS3-Tornadoflasher 6 07-15-2005 09:33
C25 does not work after flash with 5108 c25_f51 x1x to x45/x50 0 05-16-2000 16:05
Page generated in 0.15358 seconds with 9 queries
