Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 05-12-2006, 11:24   #136 (permalink)
gsmspecialist2's Avatar
Member: 66001
Thanks Meter: 16
Originally Posted by bogtheman
10x -minorKa- vbmenu_register("postmenu_1376261", true); ur the best man.. ever. i unloked my .. zv10 .. whit.. that tutorial .. !! 10x u all !! best forum ever !!
can you post the tutorial here please cause i have a zv10 locked to vodafone and i want to unlock it !
Old 05-12-2006, 12:40   #137 (permalink)
Member: 56946
Thanks Meter: 13
Originally Posted by Unlock_Ireland
I couldn't get the above program working for me . But I have successfully unlocked two Samsung Z104v's .
I used the Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 program with the USB cable that comes with the phone, the LG U8120 USB/Com cable didn't seem to work for me with the Samsung_Z105_Z107_Z300_Code_Reader_2_0_2 program.
Anyway I'm happy , one was locked to Vodafone UK the other to Vodafone Ireland.
Unlock_Ireland
Unlock_Ireland, there is no file on this link. Is there another link? Pls I need to get this file, or PLEASE send it to my box [email protected], thanx a million.
Old 05-24-2006, 20:20   #138 (permalink)
Registered User
Member: 182574
Thanks Meter: 54
thx for a good solution it work for me
Unlock Z140 (Simple) with Cracked NS Dongle
My try did results......................
Download the latest CDMA drivers from the samsung site, i used a cheap Samsung data-link USB cable "PCB180USE", connect the phone to USB-port switched on with working sim (Locked on Operator), check what COM port the Samsung CDMA USB Driver has in the control panel under Phone and Modem options (all com-ports supported, com 26 in my case).
Run cracked NS Dongle chose SGH-Z107 and com-port, push "Get Info" Push "Unlock".
100% Unlocked without problems !
It should work well with the original cable that follows the phone, but i have
not tried.
Regards Warlocker
THX FOR THIS SOLUTION IT WORK FOR ME WITH Z140 V PHONE FREEZ WITH SIMPLE USB CABLE
Old 05-29-2006, 10:36   #139 (permalink)
paklink's Avatar
Member: 71321
Sonork: 100.1576579
Thanks Meter: 428
what is final sluation for zx10 unlocking ?
how to unlock it ??????????
Old 06-11-2006, 21:36   #140 (permalink)
Member: 140808
Thanks Meter: 2
z500 frozen
have two of these both frozen. Tried using Qaulcom, com port set to 4, serial pins 2 & 3 bridged. program says serial port NG. Any ideas?
Old 06-11-2006, 23:42   #141 (permalink)
Member: 140808
Thanks Meter: 2
All OK now, bad connection at serial connector, bridge soldered an old serial plug. Works a treat...Can IMEI be written? that function does not seem to work
Old 06-12-2006, 12:15   #142 (permalink)
Member: 10228
Thanks Meter: 2
Imei can be written in z500, just did it.
/Returburk
Old 06-14-2006, 15:39   #143 (permalink)
Member: 274591
Exclamation
yes i unlocked my zv10 but now i have a problem whit this version of fimewire i mean zv10buej7 it has wap problems when u try to use browser.. phone turn off and resets? anybody know why?
Old 06-18-2006, 15:17   #144 (permalink)
Member: 151271
Thanks Meter: 23
Any one can help me for flash Z140v
I like flash Samsung z140v and i need flash and soft,
Thanks for all
Old 06-19-2006, 14:57   #145 (permalink)
Member: 295350
Z300 , how unlock?
Originally Posted by -minorKa-
This is a post to help everyone that has a Samsung Z serie mobile that is locked and/or freezed.
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.co...USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
'…………………………………………... ŻŻŻŻŻ
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked.
Hope this thread was usefull and enjoy your phones without restrictions.
i tried to down load the QUALCOMM UNLOCKER but the file is not there do u have it by any chance that you can send me???
Old 06-19-2006, 14:58   #146 (permalink)
Member: 295350
Z300 , how unlock?
i tried to downlaod the QUALCOMM UNLOCKER but i cant find the file there any one has it ?? can send to me???
Old 06-19-2006, 15:05   #147 (permalink)
Member: 295350
I have a X660 that i try with the *#9998*3323# and then *0141# to personalezd but it dosnt work because it stil asking for network code and i tried 00000000 but no use and i ask some one alls he telling me that there is a way to unlock thru IMEI . My phones imei no is 357994/00/405657/1 can any one help???
Old 06-19-2006, 21:09   #148 (permalink)
Member: 272712
just unlocked my z500 first time. got a tip for all people tying this. to join pins 2 and 3 on the com1 port i used a jumper switch from the back of an old hard drive, fits perfectly
Old 06-19-2006, 21:52   #149 (permalink)
Member: 165091
Thanks Meter: 7
bon jour tlm moi je cherche le flash de samsung z140v aide moi svp
Old 06-24-2006, 10:27   #150 (permalink)
UEM
Member: 66099
I've changed IMEI on my Z-300 just using the NsDongle.
You can get it here http://rapidshare.de/files/6388471/F...ACKED.rar.html
There is the "unlock button" there too. I didn't try it, but I guess that it works.
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! mk Z3X-Team Products 34 12-26-2008 18:19
please Mr.Elco support unlock and flash for samsung A727 ASAP tsarkh NSPRO 2 06-26-2008 10:20
Free unlocker and flasher for samsung D600 jignesh_1000 Samsung Flashers, Software, Firmware. 20 03-30-2007 08:35
Cruiser doubt... does unlocking and/or changing language erases memory? UnlockBR Cruiser Suite 9 12-29-2004 18:40
Page generated in 0.30844 seconds with 10 queries
