Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 09-15-2007, 16:32   #1 (permalink)
Member: 475309
Thanks Meter: 7
nokia 2112 signal faded call was lost problem
Nokia 2112 network problem saying "signal faded call was lost" and call drops, and some times searching for network and network comes and goes and not showing reliance in the screen. What should i do write pm or any other solution please help.
The Following 2 Users Say Thank You to jay k sundrani For This Useful Post:
Old 09-16-2007, 12:15   #2 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
this is uem problem
bro power ic is damage no solution for2112
chenge power ic
Old 09-20-2007, 13:39   #3 (permalink)
sonumobile_1's Avatar
Member: 363250
Thanks Meter: 47
write pm 100% ok
i tested
The Following User Says Thank You to sonumobile_1 For This Useful Post:
Old 09-20-2007, 13:57   #4 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
Originally Posted by sonumobile_1 View Post
write pm 100% ok
i tested
its not a permanent solution.....
Old 09-20-2007, 15:28   #5 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
sir......i give up to this problem......no trstued solution yet....
Old 09-20-2007, 23:26   #6 (permalink)
Member: 556071
Thanks Meter: 7
2112 PM Tested
I think it has 2 alternate :
  1. Perhaps your pm was bad (try to write a new pm first before take an action to hardware)
  2. The PA was bad n should be change
Here is some PM 2112 that i`ve tested
I hope it could help your problem
The Following User Says Thank You to cyclone_soft For This Useful Post:
Old 10-26-2008, 07:12   #7 (permalink)
Member: 835235
Sonork: kamalsikhwal
Thanks Meter: 4
write pm 100% ok netw
Old 01-15-2010, 14:59   #8 (permalink)
Member: 1145793
Thanks Meter: 2
back to basics........have you tried cleaning/changing the antenna?
Old 01-30-2010, 16:11   #9 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 141
2112 call failed
just reball the flash ic. ur problem 100$ solved
Old 01-30-2010, 16:41   #10 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Brother Flash I.C Just Keeping System Or Control Handset Program
P.F Control Network Or Network Control Call
Ok
Old 03-12-2012, 06:03   #11 (permalink)
Member: 1724580
Thanks Meter: 10
Phone Problem
Directly go and meet any Nokia services shop and do what they say, i think this could be better option for you friend.
thanks n regards
hansy
2112 singal failed call was last deepaksawdia Nokia CDMA 1 09-21-2009 07:53
nokia 2112 in call drop, call ended, no outgoing ashish mobile Nokia Hardware & Hardware Repair 0 05-02-2009 07:53
nokia 2112 call faield tshooter Nokia CDMA 0 06-08-2007 12:36
2112 signal ok but can't make a call sl45ind Nokia CDMA 7 01-15-2007 19:55
Page generated in 0.24045 seconds with 10 queries
