Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 03-05-2008, 06:44   #1 (permalink)
swechacnu's Avatar
Member: 115144
Sonork: 100.1590698
Thanks Meter: 498
Thumbs up NOKIA1325 & 2505 show Only Battrey Point & Set is restart.
NOKIA1325 show Only Battrey Point & Set is restart.
How Solw this problem pls help.
I have original 1325 cable but problem not solved.
The Following User Says Thank You to swechacnu For This Useful Post:
Old 03-05-2008, 07:34   #2 (permalink)
chinchik's Avatar
Member: 145494
Sonork: 100.111656
Thanks Meter: 18,407
you have to change 6610 ic from your handset it will ok otherwise you have too flash
Old 04-12-2008, 10:38   #3 (permalink)
ccipo's Avatar
Member: 68610
Thanks Meter: 7
more detail plsss.....
Old 08-19-2008, 20:44   #4 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i also have one set with this same problem , i tried to flash the set in emergency mode ,
but i am unable to enter emergency mode ///
how to enter into emergency mode or is there any other way to repair this problem ?
Old 08-22-2008, 12:09   #5 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
with fully charged battery press *+5+power button for emergency mode.but i think blinking problem is hardware because i tryed in 5 sets to flash but no result
Old 08-23-2008, 06:07   #6 (permalink)
~Gsm_Solutions~'s Avatar
Member: 141269
Thanks Meter: 28
Can u please tell me which cable did u use.As posted in various forums cable schematics were didn't work for me.So please post the pinouts for both the models.
Thanks in advance.
Regards,
Old 08-23-2008, 06:11   #7 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,911
use moto 261 usb cable its tested
Old 08-23-2008, 19:13   #8 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
how can we use usb cable ? will the software with virtual com ports ?
Old 08-28-2008, 06:54   #9 (permalink)
Member: 763260
Sonork: 120379930
Thanks Meter: 488
Cool
Nokia 1265 / 1325 UFS HWK JAF RJ45 cable 7-pin
It is an additional wire for above phones to connect with Griffin Box, Twister Flasher, Tornado Box (UFS2, UFS3), N-Box, cloned Prodigy, MT-Box, JAF, HWKuFs, HWK and all other boxes with compatible RJ45 socket.
The Following User Says Thank You to jolin2000 For This Useful Post:
Old 12-22-2009, 16:34   #10 (permalink)
Member: 919494
Thanks Meter: 6
Nokia 1325 Restart Show Only Battery Point 1000000% Solve
Brother This is Software Problem 100000000%
i'm Tryed 20 Handset over Flash With Emergency Mode {*+5+Pwr}
10000000% Solve Your Problem
E-mail [email protected]
The Following 2 Users Say Thank You to Mohd Amjad For This Useful Post:
Old 02-14-2010, 14:10   #11 (permalink)
Member: 355291
Thanks Meter: 20
plz upload flash file and software ........
Old 02-14-2010, 16:54   #12 (permalink)
bowram's Avatar
Member: 502666
Sonork: 100.1590924
Thanks Meter: 39
Sir where is cable pinout ?....
Old 02-14-2010, 17:12   #13 (permalink)
ROEZT's Avatar
Member: 508048
Thanks Meter: 123
try ccs by mxkey..
good luck....
Old 02-15-2010, 16:14   #14 (permalink)
bowram's Avatar
Member: 502666
Sonork: 100.1590924
Thanks Meter: 39
But Sir where is cable pinout???????????????????
Old 02-16-2010, 06:14   #15 (permalink)
Registered User
Member: 100376
Sonork: 100.1591842
Thanks Meter: 150
use t191 serial cable & remember set will be shown in emergency mode only(*+5+pwr) then connect with css tool & flash
The Following User Says Thank You to sabby_singh For This Useful Post:
Easy way 3110 show only nokia logo & restart mr. uem Nokia Base Band 5 ( BB-5 ) 20 02-25-2012 17:23
n73 china when i power on with sim set is restart shani72 Chinese Models & Cloned Phones 3 01-30-2009 17:38
NOKIA1325 show Only Battrey Point & Set is restart. damoder Nokia CDMA 11 11-06-2008 10:27
x160 when call set is restart shaheb_anl UST Pro II 5 06-02-2008 05:28
Samsung x640 & x460 show only start-up logo khem Samsung Hardware Repair 19 09-28-2007 22:32
Page generated in 0.26456 seconds with 11 queries
