Off Topic Zone Here all other messages... |
11-19-2018, 03:57 | #1 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | how to recover file from a dead hardrive Any way i can recover them even though it involes buying a new hardrive and doing some experimentation. Its a WD |
03-27-2024, 19:11 | #4 (permalink) |
Junior Member Join Date: Apr 2021 Location: Argentina Age: 35
Member: 2985358 Status: Offline Thanks Meter: 1 | I faced the problem of a dropped hard drive, so I feel you. First of all, check your OneDrive or iCloud, depending on what you are using, Windows or Mac. Sometimes files are automatically backed up there. As your HD was damaged physically, I still recommend contacting data recovery experts. And one more tip. Even if you are lucky enough to recover the lost data with the software on your own, my advice is to buy a new hard drive or replace the damaged one if it’s still under the warranty, because it’s no longer a reliable backup source. Hope it helps and good luck! |
