06-24-2008, 20:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | w200 can not unlock -- Reading Info--------------------------------------------------------------- User selected phone W200 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 51 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 354269-01-105683-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 51 Hint : Now the probe might be disconnected Processing ... - Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 51 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 354269-01-105683-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 51 Hint : Now the probe might be disconnected Processing ... | Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 51 NOR Flash ID = 2019 OTP Status = LOC i am using siemens TP, please what is wrong thanks for your support regards leroi |
06-25-2008, 18:14 | #3 (permalink) |
Member: 107916 Status: Offline Thanks Meter: 30 | dear sir i want to know if the TP for siemens phone can be used for SE phone. because i am using original siemens TP who was provided with dream box siemems activation. please i need your support regards teddy |
06-27-2008, 11:24 | #6 (permalink) | |
Freak Poster Join Date: May 2002 Location: Philippines
Member: 11647 Status: Offline Thanks Meter: 26 | Quote:
it can not unlock w200 | fone | Cruiser Suite | 8 | 08-23-2008 05:34 |
6300 can not unlock, downgraded, full flashed, not helped! It's Lock!! | Wais777 | BB5BOX | 3 | 04-25-2008 21:15 |
there is no hope from mr Julvir, I can not Unlock X1-X5, anybody can help me!? | KUBAT1 | SwS_SaG_BoX | 6 | 05-16-2006 11:17 |
tornado 1.2n can not unlock 7600 but griffin can | saiful2001 | UFS2 + UFS3-Tornadoflasher | 2 | 04-11-2004 06:07 |
