06-21-2006, 03:56 | #1 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 93339 Status: Offline Thanks Meter: 27 | Error 302723 Flashing or Unlocking K510a This is the log: Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: xxx Flash ID: 897E Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "K510_R4CH003_HONG_KONG.mbc" MAIN flash sent OK Switch phone ON Send FLASH application Checking FS flash file Send FS flash file: "K510_R4CH003_HONG_KONG.fbc" FS flash sent OK Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: xxx Flash ID: 897E Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R4CH003_CXC1250233_HONG_KONG_CO Send FLASH application Write GDFS Flashloader ERROR: 302723 Battery is FULLY charged I tried with the 3 flashes on the support, Generic, China, Hong Kong... PLEASE HELP!!!!!!!!!!!! PHONE IS DEAD!!!!!!! |
06-22-2006, 00:50 | #3 (permalink) |
Member: 93339 Status: Offline Thanks Meter: 27 | Hey, i solved this problem... i did the flash with a really 100% charged battery, and all was OK. I charged the battery with another phone, when the phone said fully charged i put it on the dead phone, did a flash + fs + complete ... OK!! ... then for unlock i had to charge the battery again to make it fully charged... i don't know why but is the only way to flash this K510... i flashed a lot of others K510 with non-full charged batterys without problems... |
07-04-2006, 12:07 | #5 (permalink) |
No Life Poster Join Date: Nov 2001 Location: tunisia medenine Age: 56
Member: 7599 Status: Offline Thanks Meter: 14 | problem solved with setool z530i GUI v0.91380031/UNI Card serial:00003252 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Loader:060305 1000 104_DB2010_FLASHLOADER_P5G_CXC1326738 OTP status:0 locked:1 CID:49 PAF:1 IMEI:------------ CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS 'TESTPOINT OK' Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACTPRODUCTION_CRIPPLED_LOADER_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R6AC001_CXC1250454_GENERIC_MU Restore from:R6AC001_CXC1250454_GENERIC_MU Setting up gdfs... Clearing total time... Writing simlocks... Signing... control keys complete. full sig complete. Unlock Done Elapsed:86 secs. |
how to flash or unlock 3360 tdma using tornado | WIDE | UFS2 + UFS3-Tornadoflasher | 4 | 02-04-2006 06:15 |
How to use UFS2 - Samsung Section ( Flash or Unlock ) | panji_millenium | UFS2 + UFS3-Tornadoflasher | 11 | 05-12-2004 12:23 |
