Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Samsung (USB-Smart)
Old 06-13-2006, 06:06   #1 (permalink)
rajan nishchal's Avatar
Member: 75612
Arrow Trick To Unlock Samsung T809
TRICK TO UNLOCK SAMSUNG T809 BY UFS
1) USE T809 UFS CABLE
2) SELECT D820 MODEL INSTEAD OF T809 MODEL IN UFS
3) PRESS MOBILE INFO IN UFS SOFTWARE
4) USE WITHOUT BATTERY
YOU WILL GET CODES IN SEC ENJOY
Model : Samsung Z510, Z320i :
1- Switch ON your phone without sim card,
2- Compose : **CODE#
Model : Samsung Zxxx & Dxxx Series :
2- Compose : #7465625*638*CODE#
Model : All others Samsung
2- Phone will ask for "Password",
3- You can now enter the unlock code we sent to you.
OR (if phone show "insert correct sim card")
2- Compose : #0111*CODE#
Old 06-15-2006, 10:26   #2 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
do u have pin location for SAMSUNG T809 cable for UFS ?
br
RNC_EBM
Old 06-17-2006, 05:40   #3 (permalink)
Member: 241767
@rajan
have u tried this one bro? does it works?
Old 06-17-2006, 14:36   #4 (permalink)
A1 Cell Solution's Avatar
Member: 25759
this is cable used with ufs
Old 06-17-2006, 16:49   #5 (permalink)
fgl30's Avatar
Member: 27881
For me UFS doesn´t read correct
Old 06-23-2006, 10:15   #6 (permalink)
asmar's Avatar
Member: 18966
Sonork: 100.88503
yes working 10x i use this one to enter code
best regards
Old 06-23-2006, 10:34   #7 (permalink)
ihsanali's Avatar
Member: 23939
post here correct pinouts for t809 cable
Old 06-23-2006, 22:05   #8 (permalink)
Member: 67562
Sonork: none
Simple buy new cable for T809 and forget about pinouts.
Old 06-24-2006, 02:54   #9 (permalink)
fgl30's Avatar
Member: 27881
No, my cable works great with another sw..... no cable problem for sure
Old 07-01-2006, 11:56   #10 (permalink)
Member: 10946
It works ok with those codes
thanks a lot
Old 07-05-2006, 08:18   #11 (permalink)
Member: 71212
best regards
Pls can someone help me how to unlock samsung x640, it has code only in the field k6, all the other fields are 00000000.
Thanks
Old 07-05-2006, 12:32   #12 (permalink)
Fantoz's Avatar
Member: 172678
thanx my freinds gr8 work
Old 08-28-2006, 00:41   #13 (permalink)
Member: 210669
- *2767*3855# let it reboot
then enter...
- *7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
- #7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
- *#7465625#
use this method and you will be able to unlock T809, 100% tested by me
The Following User Says Thank You to kava For This Useful Post:
small trick to unlock samsung D900i E740 zaki_barika Multi-Box 8 04-27-2008 18:24
Unlocked samsung t809 will not connect to internet blaze818 SWIFT Platform 4 01-22-2007 05:18
Help to unlock Samsung T809 commanddos SWIFT Platform 0 10-05-2006 00:32
I can't unlock Samsung T809 kingfans123 NSPRO 0 04-06-2006 17:16
Page generated in 0.40811 seconds with 12 queries
