Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 11-06-2003, 23:50   #1 (permalink)
foufou's Avatar
Member: 18703
Max 3232 in old universal box
i have old universal box based whit Max 232
can i change just Max 232 whit Max 3232
or i nned other change in the box, if yes
please shemas for univirsal box whit Max 3232
thanks for all replay
Old 12-01-2003, 08:47   #2 (permalink)
SPUnlock_SK's Avatar
Member: 13922
you may change MAX232 to MAX3232 but you must change supply from 5V to 3V because MAX3232 is 3V IC
Old 12-01-2003, 08:50   #3 (permalink)
foufou's Avatar
Member: 18703
how to make
shematic please
Old 12-01-2003, 20:40   #4 (permalink)
mr_x4you's Avatar
Member: 4989
Wrong !! 3232 can be powered between 3,6 and 5v !!! replace 232 with 3232 and change also pump capacitors to 0,1uF. If you supply 3232 with 5v, your peak on tx will be 3,6v, if you supply with 3,6 peak will be 3 V.
Old 12-02-2003, 08:46   #5 (permalink)
foufou's Avatar
Member: 18703
i change just 10uF capacitors to o,1uF?
or all pump capacitors 10uF(4ps) + 47uF(1p) + 470uF(1p) ?
big thanks for replay
Old 12-03-2003, 04:20   #6 (permalink)
cniky's Avatar
Member: 29394
replace just 10uF capacitors with 0,1uF.
Old 12-03-2003, 06:53   #7 (permalink)
foufou's Avatar
Member: 18703
big thanks
Please activate new update in old et box EMOTION BBSR UCT (Universal China Tool) by ET 10 03-16-2010 13:21
Need Old Universal Box .. .::BHATTI::. Wanted Products 0 04-21-2009 09:54
New Solution: New Hwk From Micro Box In Old Ufs3 Box NAZTY HWK 0 03-31-2008 11:09
Wanted use/old universal box urgently sunil9200 Wanted Products 0 02-21-2006 04:03
140 cables in the Universal Box Victory Eagle from Lante Raskal Unibox 28 12-26-2004 22:13
Page generated in 0.45592 seconds with 11 queries
