Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 02-28-2018, 12:34   #46 (permalink)
Member: 1988922
naviplus go blink after loading solution please
Old 03-13-2018, 07:51   #47 (permalink)
Crazy Poster
Member: 2601523
Thanks Meter: 19
repair Naviplus pro3000 - guide -
remove adapter, or update the machine by new bin file
Old 03-25-2018, 22:08   #48 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
Originally Posted by vipprog View Post
more pro3000s adapter and user manual, pls check:
https://www.vipprogrammer.com/news/u...-post-680.html
does ipad adapter support all nand as standard adapter?
Old 03-26-2018, 17:05   #49 (permalink)
Member: 67450
Thanks Meter: 57
yes support all nand
Old 04-16-2018, 05:00   #50 (permalink)
Member: 2287795
Thanks Meter: 2
file not work. Any solution?
Old 04-16-2018, 05:43   #51 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
Formatted and on root of the sdcard?
Sent from my SM-G955U using Tapatalk
Old 05-04-2018, 23:36   #52 (permalink)
Member: 2493845
Sonork: celular. express@outlook.
naviplus 3000
friend we need urgent solution we are reseller of your product your update disabled your equipment leaving blocked on start install please help us
Old 05-08-2018, 23:42   #53 (permalink)
Member: 792851
Thanks Meter: 136
Originally Posted by abbassat1974 View Post
v1.1302
Hi yes i have same problem after update with V1.1302 mass write mode disable how to active this,now when i change new hdd to update to 16 gb to 128gb phone can not active even we write correct info we need solutions plz
Old 05-12-2018, 15:02   #54 (permalink)
Member: 2814612
Same here. Installation goes perfect and succesfull but it keeps getting to the same screen over and over. Start Install window
Tried V1.1298/V1.1300/V1.1301/V1.1302
Old 05-13-2018, 00:21   #55 (permalink)
Member: 388862
Thanks Meter: 107
Originally Posted by s@lwos View Post
Hello to all friends ...
There is a tutorial which explains step by step using this programmer for NAND?
PRO3000 _1.1302
ok?
https://pan.baidu.com/s/1wAvklhcD4Wf7XYLwAAdX0A
p2s3
Old 05-13-2018, 23:21   #56 (permalink)
Member: 792851
Thanks Meter: 136
Originally Posted by lihua View Post
this is not guide its file to update naviplus he want full guide for naviplus
i can not find proper guide as well
i m having issue i have 3 divise good working device need to change 16gb to 128gb when i do that after restoring it saying phone can not active,but when i put back old 16gb hdd works,so i dont know why i think naviplus new version do not copy data proper,if someone has proper guide plz share here
Old 05-19-2018, 06:24   #57 (permalink)
Crazy Poster
Member: 1417534
Thanks Meter: 4
I THOUGHT they did that for the reason below
v1.1301 and v1.1303 disable the 'mass write mode' in configer interface.if enable the mode,when write NAND second time with the same FW,it will modify the last 2 byte of WIFI MAC automatic and when restore,it can't be active.
Old 05-19-2018, 06:26   #58 (permalink)
Crazy Poster
Member: 1417534
Thanks Meter: 4
i mean version 1.1301 and 1.1302
Old 05-19-2018, 06:30   #59 (permalink)
Crazy Poster
Member: 1417534
Thanks Meter: 4
i thaught the did it for this reason below.
v1.1301 and v1.1302 disable the 'mass write mode' in configer interface.if enable the mode,when write NAND second time with the same FW,it will modify the last 2 byte of WIFI MAC automatic and when restore,it can't be active.
Old 05-20-2018, 23:33   #60 (permalink)
Member: 792851
Thanks Meter: 136
so what to do? i have same issue i m writing 16gb hdd to 64gb hdd but can not active how can we fix wifi mac last 2 word dont get change?
Page generated in 0.26114 seconds with 9 queries
