Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
View Poll Results: we must have an oscilloscope to repair hardware
yes 1,117 72.39%
no 437 28.32%
Multiple Choice Poll. Voters: 1543. You may not vote on this poll
Old 09-03-2017, 12:01   #286 (permalink)
Member: 1714728
Thanks Meter: 11
In simple words multimeter is only a photo shot but a oscilloscope is a video it will show what is happening an when it is happening.
The Following User Says Thank You to shivashaker For This Useful Post:
Old 09-03-2017, 12:09   #287 (permalink)
Member: 2752701
That makes sense. But where can I start learning how to use the oscilloscope?
Any videos on YouTube?
Sent from my ONEPLUS A3000 using Tapatalk
Old 10-10-2017, 15:56   #288 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
For sure there are....
Do a good research
Old 10-18-2017, 18:34   #289 (permalink)
Member: 2760082
Wink
Scope for repairing......???
I do not tink so.
Old 10-24-2017, 14:35   #290 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
I do not tink so.
Depends what has to berepaired.
It for sure hepls in finding where the fault might be....
The Following User Says Thank You to excessive For This Useful Post:
Old 11-04-2017, 20:50   #291 (permalink)
Member: 1972075
for gsm like dead board it is no point for having expensive osciloscope
The Following User Says Thank You to damian_zet For This Useful Post:
Old 09-10-2018, 09:17   #292 (permalink)
Member: 1509175
The multimeter and the mind of mechanic is best tool for finding the fault dead short
Sent from my SM-G7102 using Tapatalk
The Following User Says Thank You to sbhajband For This Useful Post:
Old 01-13-2019, 22:20   #293 (permalink)
Member: 2807920
Thanks Meter: 3
Personally I get around using cheap *** multi meter (25$-ish aneng an8009) and 300$ hantek scope.
I use multi meter for tracking shorts, reading diode readings and measuring resistance to ground (Diode, continuity and resistance is what I use on it.),
When I have some phone, laptop or something that uses I2C or SPI I check clokc and data pins on my scope to look at integrity of signal.
Sometimes when I do reverse engineering i use logic analyzer, but that is not often.
So basically oscilloscope is just glorified multi meter if you look from basic stand point, good side is that it shows voltage change per time, that can help you check quick shorts on power supplies or something like that.
The Following User Says Thank You to VeryFastSnail For This Useful Post:
Old 02-12-2019, 12:56   #294 (permalink)
Member: 1489453
Good morning , how can one acquire some of the hardware machines
Old 02-28-2019, 21:26   #295 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Thanks Meter: 523
Wink
Till 2006 I have used an 10MHz old romanian analog oscilloscope.
After, I have used an Philips PM3065 and a Philips PM3370b till 2016.
Since 2016 I am using another combiscope but an Hameg HM1508-2.
Regarding the use of an oscilloscope, it depends by what you know and
what other things you do with it.
For more than 8 years I use only professional lab tools instead of chinese tools.
Best Regards!
The Following 3 Users Say Thank You to Burebista For This Useful Post:
Old 09-08-2019, 04:32   #296 (permalink)
Member: 1829499
Thanks Meter: 2
An oscilloscope is nice to have but they don't come cheap. A multimeter should be all you need and a brain.
Old 12-11-2019, 15:11   #297 (permalink)
Member: 2923502
Thanks Meter: 6
What do you think about use lap top oscilloscope for phones repair or use small sound card (costs about 10$) to safe lap top sound card
Old 12-14-2019, 06:59   #298 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
Portable USB oscilloscope probe can be used. Not sure about the best results but it’s a good start without spending too much.
The point here is: do you know how to use an oscilloscope?
If you have a lab and do any kind of electronic repairing then is definitely useful. To start with, buy a cheaper solution as gsmphonerepair is suggesting and start learning how to use it. Buy a good book and experience a lot.
Regards,
X4ce
Sent from my iPad using Tapatalk
Old 05-28-2020, 15:30   #299 (permalink)
Member: 2954885
You Read the Manual inside the box if you have it, otherwise visit google or youtube for Tutorials
Old 10-27-2020, 08:14   #300 (permalink)
Member: 2968254
Sonork: firat ayrılmazkardes
Multimeter is best tool i use in gsm enginering. Thats the truth
Which is the best gsm field to Work??? sallu GSM Programming & Reverse Engineering 8 03-22-2007 07:14
what is the best route to buying cdma equipment jesto80 Various CDMA/TDMA Cell Phones 1 03-13-2007 04:01
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! hackgsm.net Main Sales Section 0 03-27-2005 11:59
All the best GSM Hardware devices! stargsm Main Sales Section 0 03-11-2003 19:53
Page generated in 0.31191 seconds with 11 queries
