Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
05-05-2002, 18:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 4270 Status: Offline Thanks Meter: 13 | uBGA Removal and replace tools ??? I am searching for a uBGA removal and replacement tool. I have seen many machines that can do it 100% but i wanted to find out which is the best and also where can i find it. I have been told about a machine that will remove the CPU on 3310, 8210 and other phones with a similar CPU 100000% and replace from another phone, what is the possibilities of this ? hope some1 has some info on this. regards reo |
05-24-2002, 17:37 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya Best tools for uBGA rework are Zevac and OK International ( Nokia service uses them ) but they are high $$$ For other mortals uBGA kits from our chinese friends are OK. Get the BGA kit, hot air bga rework station ( quick 850 is OK but i use home made one), NO CLEAN Flux ( don't use any honey flux ) and that's it... U need also some experience how to do it... Removing NOKIA uBGA ( and all others ) is easy unless they are glued to mainboard. If they are sealed u will need special melter to remove glue first. DO NOT try to reflow glued components heating directly the chip or u will kill phone. Try to heat chip from other side, heating the board. AND DO NOT exceed 220 - 250 degrees temperature or u will broke PCB BR Vule |
05-26-2002, 23:20 | #4 (permalink) |
Junior Member Join Date: Jan 2002 Location: BG
Member: 8777 Status: Offline Thanks Meter: 0 | Glue removing? > Removing NOKIA uBGA ( and all others ) is easy unless they are > glued to mainboard. If they are sealed u will need special > melter to remove glue first. Which is this "Melter"? |
05-27-2002, 16:32 | #5 (permalink) |
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya A " melter " is substance for removing seals on NOKIA phones. Pardon my english but i could not remember any other word for it lol........ BR Vule |
06-19-2002, 13:20 | #8 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | Hi I am also interested in uBGA tools. Which one is advised? I need it from Europian countries because I don`t think it will safely come from China. Can anybody give good and reliable web site? Best Regards Sean Archer |
Step by Step-how To remove & replace COBBA / CCONT very useful to beginner... | silveraxe | Nokia Hardware & Hardware Repair | 8 | 07-03-2007 18:24 |
how remove and replace the CPU? | nkakanou | Hardware Equipments for GSM | 0 | 08-22-2006 20:54 |
USB Dongle - need to remove then replace for LAN connection | djc_slip | Bluetooth-Software | 1 | 02-05-2005 22:08 |
3310 after switching off, will only switch back on if you remove and replace battery | bilbo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-2003 00:41 |
uBGA Station and Tools ? | Bph&co | Hardware Repair by brands | 5 | 08-22-2001 03:17 |
