07-23-2006, 19:41 | #76 (permalink) |
Freak Poster Join Date: Jan 2002 Location: sp coastline
Member: 8802 Status: Offline Thanks Meter: 16 | Thanks |
07-28-2006, 16:14 | #77 (permalink) |
Freak Poster Join Date: Feb 2004 Location: morocco
Member: 55442 Status: Offline Thanks Meter: 83 | i can send you key file for free :) for this (bad key file) or (key file not found) send me your SN and i send you your working key file :=) no good support help from juliver |
07-28-2006, 22:12 | #78 (permalink) |
Freak Poster Join Date: Jan 2004 Location: algeria Age: 49
Member: 49066 Status: Offline Thanks Meter: 5 | in reality this cause is not correct 100%. if you execute the soft & 5volt not connected, what happen? answer for this question : no thing. & answer to the big question the conception of the electronic circuit, may be the problem is exactly in power of many ics. |
07-29-2006, 00:29 | #79 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | nefhamid my 1st redbox was killed (bad S/N) after I execute sw for redbox but no 5 volt connected, try with yours and see. redbox is very sensitive for things like that. |
07-29-2006, 18:42 | #80 (permalink) |
Member: 8802 Status: Offline Thanks Meter: 16 | Of course, I'm sure that it is not key problem. The diode is ****n and it is a power suply problem, or something worse. If the ic is affected no way to solve it. Now the only way to know it is change diode, but I don't know what type of diode is. |
09-21-2006, 01:54 | #81 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194302 Status: Offline Thanks Meter: 32 | I have same problem. Pls give me solution Thanks Quote:
09-27-2006, 00:45 | #82 (permalink) |
Member: 49066 Status: Offline Thanks Meter: 5 | d2= 1n4148. & to resolve your problem eleminate the bleu LED, disconnect other perepherals that connected to USBs ports, & you try to execute the soft. |
01-02-2007, 14:00 | #83 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | Hi. Is there any one can supply me pic ic in box? If yes how much does it cost? My RED box died 1 year ago after few unlock. I need to repair. Unless this is now child toy. I payed $$$ for this. Strangest box I ever used. thank you for attention. |
01-22-2007, 17:35 | #86 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | any one can help me to repair my redbox it display bad key in need software to repair key best regar abel [email protected] |
Keep your sliding lock key safe - Excellent MyKeylock for 5800 | Itz_Mee | Nokia Multimedia | 0 | 11-22-2009 18:20 |
Whats do you use your redbox for | bowei | Redbox | 6 | 07-12-2009 17:22 |
Instant bb5 rpl from no.1 server.. Keep your customers safe | makona | Main Sales Section | 0 | 04-01-2009 04:07 |
How To Safely Disconnect Redbox | sunrise gsm | Redbox | 1 | 01-11-2005 11:14 |
