Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2002
Member: 15162 Status: Offline Thanks: 18
| Sws Sagem Dongle :-read How To Make Cable And Solved Errors HI all with latest version it is working 100% .If you have key not found,then try to use a new windows .for me working on xp.Try also on another computer If you have problem on 20,40 % then stop,it is 100% cable problem. MAKE A NEW CABLE AND DON'T LOOK AT COLOUR WIRE . LABEL EACH WIRE PIN1 ,PIN2 ,PIN3 ,PIN 4,PIN 5 ,PIN 6 ,PIN 7 ,PIN 8 DETAILS RJ45 PIN 1 IS FOUND ON THE RIGHT HAND SIDE OF SWS BOX THAT IS ON THE RED LIGHT SIDE AND THE USB PORT. RJ45 PIN 1 AND RJ45 PIN8=GND GOES TO PHONE CONNECTOR RJ45 PIN2=TEST POINT RJ45 PIN3=TEST POINT RJ45 PIN4=RX GOES TO PHONE CONNECTOR RJ45 PIN5=TX GOES TO PHONE CONNECTOR RJ45 PIN6=TEST POINT RJ45 PIN7=TEST POINT LABEL EACH WIRE PIN1 ,PIN2 ,PIN3 ,PIN 4,PIN 5 ,PIN 6 ,PIN 7 ,PIN 8 WHEN UNLOCKING PHONE:- Example myc5-2 testpoint on support page is:- pin2 green ,pin 3 orange ,pin6 brown ,pin 7 blue. Don't look for colour .just use pin number . That is pin 2 ,pin 3 ,pin 6 ,pin 7 Now look on your wire pin number and solder to testpoint pin number. Hope this can help you i have explain in very details,if any problem let me know. Cheers Djyash |
| | #2 (permalink) |
| Banned ![]() ![]() ![]() Join Date: Mar 2005 Age: 33
Member: 128695 Status: Offline Thanks: 0
| @hi yash its not working in myx-1w becoz @hi yash its not working in myx-1w becoz in sws-sag og cable i unlock myx-5m in same calbe but in myx-1w every time give bad tp erro after 40% i have redbox and i made a another cable my redbox sagem cabel and solder a wire in pcb but its give a same erro after 40% bad tp so u told me in sws-sag myx-1w unlocked or not please help me out i still waiting here for u r replay |
| | #3 (permalink) |
| make the cable as i said then try again. If you have been able to unlock myx5m then maybe new version of myx1w.Try to read it with astu then post in log section.hope field is not protected. |
| | #4 (permalink) | |
| @hi freind thanx a lot u r wirte i abel to unlcok myx-5m Quote:
| | #5 (permalink) |
| I have not unlock myx-1w ,maybe this version cannot be unlock by sws-sag,I don't know. try it with latest version if still problem then try to read it with astu. Cheers Djyash |
| | #6 (permalink) | |
| @hi freind thanx alot for replay me Quote:
| | #8 (permalink) |
| @ hi ok i will send log file on u r @ hi ok i will send log file on u r hotmail id if u want i send a another id please send me a pm ok private message ok bye and thanx a lot |
| | #10 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: I N D I A Age: 32
Member: 100579 Status: Offline Sonork: 100.1578318 Thanks: 19
| Quote:
hi. i am also facing same problem like u . i have tried more than 100 times it gives me error at 40%. But when i used full charged battery i got successed at 1st time. phone unlocked successed fully. if u r dongle and test point are correct pls try vth fully charged battery. u might get ur problem solved. regards. | |
| | #12 (permalink) | ||
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003 Location: INDIA
Member: 38103 Status: Offline Sonork: 100.100782 Thanks: 114
| Quote:
![]() Use direct connections instead zigs {TP adapters} C ya | ||
| | #13 (permalink) |
| Hi all Today i found that problems sometimes come on parallel cable ,try to change it too and in bios settings ecp+epp should work ok. Hope this can help you. Cheers Djyash |
| | #14 (permalink) | |
| @roopesh_500 thanx a lot for give me solution Quote:
by sws-sag its great box to use thanx a lot | |
| | #15 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2002 Age: 37
Member: 18938 Status: Offline Thanks: 22
| interesting Hi good post, a lot of ppl are getting confusing in same problem (including me).. Btw, why donīt someone who knows all about the cable modification problem, write about for which models concretly cable modification is need and for which not. What I think is that for old models is need cable modification and not for new ones like my55 my5-2...but Iīm not sure about it. It would be great.. and leave it stickyThanks, David |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how to make cable for w220 to unlock??? | svchost | Smart-Clip | 1 | 06-09-2009 10:28 |
| Furious BlackBerry (PACK 4) dongle - user manual - how to make it all working | F C | FuriouS TeaM Products | 0 | 03-06-2009 04:06 |
| how to make cable cruiser with test point | CONG YANG | Cruiser Suite | 1 | 01-23-2007 07:45 |
| how to make cable for blazer for lgb2050? | mmanduri | Blazer | 2 | 11-03-2005 22:12 |
