11-03-2007, 12:29 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Moldova Age: 48
Member: 55917 Status: Offline Sonork: 100.1583632 Thanks Meter: 35 | ZV60,Unsupported simlock algo Revision: ZV60BUGE4 IMEI: 35491901xxxxxxxx SIM lock password: 0000 Analyzing... ERROR - Unsupported simlock algo! What is the problem, can it be fixed ?this is my first ZV60 with this problem, till now all was ok. |
11-03-2007, 12:46 | #2 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 47
Member: 175544 Status: Offline Thanks Meter: 198 | Quote:
wbr | |
11-07-2007, 10:14 | #5 (permalink) |
Member: 55917 Status: Offline Sonork: 100.1583632 Thanks Meter: 35 | It doesn't work, I try with 2.41 too, I try with cobmo cable throu normal com1 port, I try with prolific, with Infininity, with setool and always the same thing. And I flashed the phone with BUGE3 firmware and the same thing again, and all this on 3 computers. |
11-07-2007, 10:20 | #6 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 43
Member: 55654 Status: Offline Thanks Meter: 9 | Quote:
Please add pictures for trying to help you | |
11-07-2007, 14:12 | #7 (permalink) |
Member: 55917 Status: Offline Sonork: 100.1583632 Thanks Meter: 35 | I haven't easy-unlocker box, I have just dongle, but till now I hasn't any problem in unlocking ZV60 with combo cable, and in this case I used as FTDI interface setoolbox, Infinitybox and prolificcable to unlock phone, and alwys it says Usuported simlock algo. |
11-08-2007, 12:21 | #9 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Morocco/FBS
Member: 537213 Status: Offline Sonork: 100.1577391 Thanks Meter: 362 | Quote:
If same try other Internet connexion. NOTE: i use just special cable + dongle and i don't have any problem with all supported samsung good luck | |
11-08-2007, 12:52 | #10 (permalink) |
Member: 55917 Status: Offline Sonork: 100.1583632 Thanks Meter: 35 | Maybe you can't read? I said that is the only one ZV60 that I can't unlock, I have special cable and I made many ZV60 till now, and with this phone I try with other cables beacause I can't unlock with this special cable mentioned ZV60 and I try already on 3 PC-s. |
11-08-2007, 13:07 | #11 (permalink) | |
If all tried as not success so security zone your phone damaged! | |
11-13-2007, 22:17 | #12 (permalink) |
Member: 55917 Status: Offline Sonork: 100.1583632 Thanks Meter: 35 | I don't think that the problem could be in PC and that laptop will solve this problem, the most probable is that phone has damaged security zone or something like this, and what I want to knew if there's anyway to solve this problem, I don't have anymore this ZV60 but anyway it will be good if our supporters will clarify this problem. And I want to say that with same PC and same cable I unlocked today one ZV60 and some days ago 3 Z170. |
11-14-2007, 10:23 | #13 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Any Beautiful Place Age: 45
Member: 7900 Status: Offline Sonork: 100.78126 Thanks Meter: 4,991 | If you have a phone damaged, youŽll not be able to unlock if you donŽt put correct data before read codes, so if you have anyone damaged, first of all flash phone and then read codes with Easy Unlocker. Regards ! |
Blackberry bold 9000 cant unlock UNSUPPORTED SIMLOCK TYPE PLZ CHECK | rajan nishchal | FuriousGold | 11 | 06-05-2009 15:20 |
What is slow method for Blackberry. does it work for unsupported Simlock type ? | tical | FuriousGold | 0 | 01-05-2009 13:27 |
F480 Read failed,invalid data or unsupported simlock! | vinay_sharma | UST Pro II | 3 | 12-04-2008 07:50 |
Read failed,invalid data or unsupported simlock! | younesdib | UST Pro II | 3 | 10-22-2008 20:59 |
ZV10 ERROR - Unsupported simlock algo! | Miftahudin | Easy-Unlocker | 5 | 09-29-2008 11:18 |
